NETGEAR ProSAFE 8-port Smart Managed Gigabit PoE Ethernet Switch
Quicklinx: FSRFWS00 Mfr#: GS110TP-300EUS
Type: Gigabit Ethernet
Ports: 8
Data Transfer Rate: 16
Managed: Yes
POE: PoE+
39 In Stock
£114.77 ex VAT
£137.72 inc VAT
The GS110TPv3 adds full 8 port PoE support for deployment of modern PoE devices. Cautious spender organizations can now deploy PoE devices connected to a cost effective switch, with a reasonable PoE power budget of 55W. Each port can provide up to 30 watts to power up connected devices. Fanless, the GS110TPv3 supports perfectly silent desktop operation or wall mounting.
  • Enhanced security
    With support for RADIUS and TACACS+ authentication methods, alongside TLS 1.2 encryption, the NETGEAR Smart GS110TPv3 ensures secure network access and data transmission.
  • Robust performance
    Featuring a 20 Gbps switching fabric bandwidth and a forwarding performance of 14.8 Mpps, this switch is designed to handle demanding network environments efficiently.
  • Comprehensive network management
    Manageable via HTTP, HTTPS, SNMP, and more, the GS110TPv3 offers advanced control over your network, including features like Access Control List (ACL) support, Advanced QoS, and IGMP snooping for optimized performance.
  • Power and connectivity
    Equipped with 8 PoE+ ports and a total PoE budget of 55 W, along with two SFP slots for fiber connectivity, this switch supports a wide range of devices and deployment scenarios.
  • Energy-efficient design
    The fanless design not only ensures silent operation but also incorporates ENERGY STAR for reduced power consumption, making it an eco-friendly choice for any business.
NETGEAR Smart GS110TPv3 - switch - 8 ports - smart
Switch - 8 ports - smart
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE) + 2 x SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
55 W
Performance
Switching fabric bandwidth: 20 Gbps , Forwarding performance (64-byte packet size): 14.8 Mpps
Packet buffer size: 512 KB , ACL entries (ingress): 100 , VLANs supported: 64 , IPv4 routes (static): 32
MAC Address Table Size
8K entries
Jumbo Frame Support
10KB
Routing Protocol
IGMPv2, IGMP, IGMPv3, static IPv4 routing, MLDv2, MLD
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, IPv6
IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, store and forward, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, firmware upgradable, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, MLD snooping, fanless, LACP, DHCP client, dual firmware images, loop prevention, tagged VLAN, cable test, LLDP-MED, protected ports, EEE, WRR, Advanced QoS, Unknown Storm Control, security slot (Kensington security lock compatible)
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
DC 54 V
23.6 cm x 10.1 cm x 2.7 cm
610 g
Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
55 W
Performance
8K entries
Jumbo Frame Support
10KB
Routing Protocol
Encryption Algorithm
TLS 1.2
Authentication Method
RADIUS, TACACS+
: 500 MHz
RAM
128 MB
Flash Memory
32 MB
Status Indicators
Port status, PoE, link/activity/speed
8 x 1000Base-T RJ-45 PoE+ ¦ 2 x 1000Base-X SFP
External power adapter
DC 54 V
69.5 watt
Power Consumption Stand by
4.3 watt
Wall mounting kit
MTBF
1,200,041 hours
Europe
23.6 cm
10.1 cm
2.7 cm
610 g
Limited warranty - replacement - lifetime - response time: next business day , Limited warranty - power supply - 2 years , Technical support - phone consulting - 90 days
95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Ports: 8
Managed: Yes
POE: PoE+
Brand: NETGEAR
