NetGear Prosafe 8-Port Plus Switch
LIFETIME WARRANTY
Quicklinx: 9S0BWS00 Mfr#: GS108E-300UKS
Type: Gigabit Ethernet
Ports: 8
Data Transfer Rate: 1Gbps
Managed: No
POE: No
£25.82 ex VAT
£30.98 inc VAT
At NETGEAR the importance of a stable and robust network infrastructure is understood. ProSAFE products are designed to exceed the high standards required of business-class network.
  • Robust performance
    With a bandwidth of 16 Gbps, the NETGEAR Plus GS108Ev3 ensures efficient handling of network traffic, facilitating smooth data transmission across all connected devices.
  • Versatile connectivity
    Equipped with 8 RJ-45 connectors supporting 1000Base-T for Gigabit Ethernet, this switch offers ample ports for connecting multiple devices, making it ideal for expanding your network.
  • Durable design
    Designed to operate within a wide range of temperatures, from 0°C to 40°C for operating conditions and -20°C to 70°C for storage, the GS108Ev3 is built to withstand challenging environmental conditions.
  • Easy integration
    Compatibility with PC systems and adherence to various IEEE standards, including 802.3i, 802.3u, and 802.3z, ensures that the GS108Ev3 can be seamlessly integrated into existing network infrastructures.
NETGEAR Plus GS108Ev3 - switch - 8 ports - unmanaged
Switch - 8 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Bandwidth: 16 Gbps
VLANs supported: 32
Network monitoring, VLAN support, IGMP snooping, DoS attack prevention, Broadcast Storm Control, Quality of Service (QoS), bandwidth control, loop prevention
IEEE 802.3u, IEEE 802.3i, IEEE 802.3z
15.8 cm x 10.1 cm x 2.9 cm
540 g
Microsoft Windows Vista / XP / 7
United Kingdom
NETGEAR lifetime warranty
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Bandwidth: 16 Gbps
VLANs supported: 32
8 x 1000Base-T RJ-45
External power adapter
MTBF
2,525,259 hours
Plug and Play, C-Tick, VCCI Class B ITE, CISPR 22 Class B, EN 60950, EN55022 Class B, CB, FCC Part 15 B
United Kingdom
Software Included
Drivers & Utilities
15.8 cm
10.1 cm
2.9 cm
540 g
0 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
0 - 95% (non-condensing)
Ports: 8
Managed: No
POE: No
Brand: NETGEAR
