At NETGEAR the importance of a stable and robust network infrastructure is understood. ProSAFE products are designed to exceed the high standards required of business-class network.
Robust performance
With a bandwidth of 16 Gbps, the NETGEAR Plus GS108Ev3 ensures efficient handling of network traffic, facilitating smooth data transmission across all connected devices. -
Versatile connectivity
Equipped with 8 RJ-45 connectors supporting 1000Base-T for Gigabit Ethernet, this switch offers ample ports for connecting multiple devices, making it ideal for expanding your network. -
Durable design
Designed to operate within a wide range of temperatures, from 0°C to 40°C for operating conditions and -20°C to 70°C for storage, the GS108Ev3 is built to withstand challenging environmental conditions. -
Easy integration
Compatibility with PC systems and adherence to various IEEE standards, including 802.3i, 802.3u, and 802.3z, ensures that the GS108Ev3 can be seamlessly integrated into existing network infrastructures.
- NETGEAR Plus GS108Ev3 - switch - 8 ports - unmanaged
- Switch - 8 ports - unmanaged
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000
- Performance
- Bandwidth: 16 Gbps
- Capacity
- VLANs supported: 32
- Network monitoring, VLAN support, IGMP snooping, DoS attack prevention, Broadcast Storm Control, Quality of Service (QoS), bandwidth control, loop prevention
- IEEE 802.3u, IEEE 802.3i, IEEE 802.3z
- 15.8 cm x 10.1 cm x 2.9 cm
- 540 g
- System Requirements
- Microsoft Windows Vista / XP / 7
- Localisation
- United Kingdom
- NETGEAR lifetime warranty
- Enclosure Type
- Desktop, wall-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000
- Performance
- Capacity
- 8 x 1000Base-T RJ-45
- Power Device
- External power adapter
- MTBF
- 2,525,259 hours
- Plug and Play, C-Tick, VCCI Class B ITE, CISPR 22 Class B, EN 60950, EN55022 Class B, CB, FCC Part 15 B
- Localisation
- United Kingdom
- Software Included
- Drivers & Utilities
- OS Required
- 15.8 cm
- 10.1 cm
- 2.9 cm
- 540 g
- 0 °C
- 40 °C
- 0 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 0 - 95% (non-condensing)
NetGear Prosafe 8-Port Plus Switch
