NetGear ProSafe 8-port Gigabit VPN Firewall Router
LIFETIME WARRANTY
Quicklinx: 7VJNWS00 Mfr#: FVS318G-100EUS
The NETGEAR ProSafe 8-port Gigabit VPN Firewall provides both secure IPsec site-to-site tunnels and IPsec secure access for remote clients. Employing a true firewall with customizable firewall rules, this VPN router is a high-performance, SNMP-manageable, network solution that furnishes multidimensional security including denial-of-service (DoS) protection, stateful packet inspection (SPI), URL keyword filtering, logging, reporting, and real-time alerts. Eight Gigabit LAN ports keep your data moving at top speed. With Network Address Translation (NAT) routing and classical routing, all the users in your small office can access your broadband connection at the same time.
  • Secure
    The FVS318G takes care of all your security needs, with support of up to 5 simultaneous IPsec VPN tunnels, hacker protection via SPI firewall, DoS attack protection, configurable hardware DMZ port, and multiple VPN pass-through. It features SYSLOG, email reporting, and integrates with network monitoring tools via SNMP. IKE authentication provides peace of mind against unauthorized VPN network access and supports industry-strength encryption algorithms to ensure protection and privacy of your sensitive data. Dedicated DMZ enables you to separate guest traffic from production data. The ProSafe 8-port Gigabit VPN Firewall provides optimal value and defense against network security threats.
  • Reliable
    At the core of the FVS318G is NETGEAR tested and proven firewall and VPN technology. The rugged metal unit houses advanced, high-quality electronics.
  • Easy to use
    Auto Detect connects to your ISP quickly; the user-friendly Web-based ProSafe Control Center configuration screen and install assistant reduce setup time. The IPsec VPN wizard automates IPsec VPN configuration and secure remote makes it simple to connect to multiple sites. Support for DHCP (client and server) as well as PPPoE allows for easy, widespread deployment. This well-built firewall has an integrated 8-port 10/100/1000 Mbps switch. Auto Uplink on the all ports eliminates the need for crossover cables.
NETGEAR ProSafe FVS318G - router - desktop
Router - 8-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Performance
Firewall throughput: 25 Mbps
IPSec VPN tunnels: 5
Network / Transport Protocol
TCP/IP, UDP/IP, ICMP/IP, IPSec, FTP, DHCP
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
SNMP
DMZ port, DHCP support, NAT support, Syslog support, SPI, DoS attack prevention, VPN passthrough, URL filtering, event log, DHCP server, port forwarding
19 cm x 12.5 cm x 3.5 cm
590 g
Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop
Wired
Performance
Routing Protocol
SNMP
Encryption Algorithm
DES, Triple DES, MD5, IKE, SHA-1, 128-bit AES, 256-bit AES
Authentication Method
X.509 certificates
1 x 250 MHz
RAM
32 MB SDRAM
Flash Memory
8 MB
LAN: 8 x 10Base-T/100Base-TX/1000Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-TX - RJ-45 , Serial: 1 x RS-232 - 9 pin D-Sub (DB-9)
External power adapter
1 x network cable
Europe
Software Included
Drivers & Utilities, ProSafe VPN Client
19 cm
12.5 cm
3.5 cm
590 g
