The NETGEAR FVS318G ProSafe 8-port Gigabit VPN Firewall provides both secure IPsec site-to-site tunnels and IPsec secure access for remote clients. Employing a true firewall with customizable firewall rules, this VPN router is a high-performance, SNMP-manageable, network solution that furnishes multidimensional security including denial-of-service (DoS) protection, stateful packet inspection (SPI), URL keyword filtering, logging, reporting, and real-time alerts. Eight Gigabit LAN ports keep your data moving at top speed. With Network Address Translation (NAT) routing and classical routing, all the users in your small office can access your broadband connection at the same time.
IKE authentication provides peace of mind against unauthorised VPN network access and supports industry-strength encryption algorithms to ensure protection and privacy of your sensitive data. Dedicated DMZ enables you to separate guest traffic from production data. The ProSafe 8-port Gigabit VPN Firewall provides optimal value and defence against network security threats.
Reliable
At the core of this Netgear FVS318G Firewall is NETGEAR tested and proven firewall and VPN technology. The rugged metal unit houses advanced, high-quality electronics, and is backed by a lifetime warranty.
Easy to Use
Auto Detect connects to your ISP quickly; the user-friendly Web-based ProSafe Control Centre configuration screen and install assistant reduce setup time. The IPsec VPN wizard automates IPsec VPN configuration and secure remote makes it simple to connect to multiple sites. Support for DHCP (client and server) as well as PPPoE allows for easy, widespread deployment. This Netgear FVS318G well-built firewall has an integrated 8-port 10/100/1000 Mbps switch and is compatible with Windows, UNIX, Macintosh, and Linux OS. Auto Uplink on the all ports eliminates the need for crossover cables.
Secure This Netgear FVS318G Firewall takes care of all your security needs, with support of up to 5 simultaneous IPsec VPN tunnels, hacker protection via SPI firewall, DoS attack protection, configurable hardware DMZ port, and multiple VPN pass-through. It features SYSLOG, email reporting, and integrates with network monitoring tools via SNMP.
Key Feature
Eight (8) 10/100/1000 Gigabit Ethernet RJ45 ports
Five (5) VPN Tunnels for Secure Remote Access
Provides both secure IPsec site-to-site tunnels and IPsec secure access for remote clients
Includes denial-of-service (DoS) protection, stateful packet inspection (SPI), URL keyword filtering, logging, reporting, and real-time alerts
Secure
The FVS318G takes care of all your security needs, with support of up to 5 simultaneous IPsec VPN tunnels, hacker protection via SPI firewall, DoS attack protection, configurable hardware DMZ port, and multiple VPN pass-through. It features SYSLOG, email reporting, and integrates with network monitoring tools via SNMP. IKE authentication provides peace of mind against unauthorized VPN network access and supports industry-strength encryption algorithms to ensure protection and privacy of your sensitive data. Dedicated DMZ enables you to separate guest traffic from production data. The ProSafe 8-port Gigabit VPN Firewall provides optimal value and defense against network security threats. -
Reliable
At the core of the FVS318G is NETGEAR tested and proven firewall and VPN technology. The rugged metal unit houses advanced, high-quality electronics. -
Easy to use
Auto Detect connects to your ISP quickly; the user-friendly Web-based ProSafe Control Center configuration screen and install assistant reduce setup time. The IPsec VPN wizard automates IPsec VPN configuration and secure remote makes it simple to connect to multiple sites. Support for DHCP (client and server) as well as PPPoE allows for easy, widespread deployment. This well-built firewall has an integrated 8-port 10/100/1000 Mbps switch. Auto Uplink on the all ports eliminates the need for crossover cables.
- NETGEAR ProSafe FVS318G - router - desktop
- Router - 8-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Performance
- VPN throughput (3DES IPSec): 30 Mbps
- Capacity
- IPSec VPN tunnels: 12 , Virtual interfaces (VLANs): 254 , Concurrent connections: 6000
- TCP/IP, PPTP, UDP/IP, L2TP, IPSec, PPPoE, DDNS
- Routing Protocol
- RIP-1, RIP-2, static IP routing
- Remote Management Protocol
- Telnet, SNMP 2c, HTTP, HTTPS
- DMZ port, NAT support, VPN support, PAT support, LDAP support, interrupt status port (ISP), VLAN support, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, ALG support, MAC address filtering, IPv6 support, VPN passthrough, URL filtering, Quality of Service (QoS), DHCP server, DNS proxy, port forwarding, IPv4 support, port triggering, DHCP relay, DHCP client, static routing, Mobile Internet Auto-Configuration Solution (MIAS), SNMP support, Type of Service (ToS)
- IEEE 802.1Q, UPnP
- 19 cm x 12.5 cm x 3.5 cm
- 590 g
- Localisation
- Europe
- NETGEAR lifetime warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wired
- Performance
- Capacity
- Routing Protocol
- Encryption Algorithm
- Triple DES, MD5, AES, IKE, SSL, SHA-1, PKI, 128-bit AES, 192-bit AES, 256-bit AES
- Authentication Method
- RADIUS, X.509 certificates, LDAP, Active Directory
- IEEE 802.1Q, UPnP, cUL, CCC, AES, RoHS, X.509 v3, FCC Part 15 A, VPNC certified, LVD, EMI, China RoHS
- Processor
- 1 x 300 MHz
- RAM
- 128 MB SDRAM
- Flash Memory
- 32 MB
- WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 8 x 10Base-T/100Base-TX/1000Base-T - RJ-45
- Power Device
- External power adapter
- Cables Included
- 1 x network cable
- Localisation
- Europe
- Software Included
- Drivers & Utilities
- 19 cm
- 12.5 cm
- 3.5 cm
- 590 g
- 0 °C
- 45 °C
- 90% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
