The WC7600 premium wireless controller is ideal for K-12 education, hospitality, and healthcare deployments. Designed with simplicity in management and ease of use, it offers enterprise grade functionality and capability for small and midsized organizations, without the cost and complexity of big IT.
Performance
UFast algorithm provides fast and easy access point discovery and firmware management. Fully distributed L2 and L3 roaming enable optimal performance and maximum throughput for seamless mobility. Automatic controls of AP transmit power and channel allocations ensure best coverage by minimizing interferences. Load balancing and rate limiting provide fair bandwidth allocation among all clients for robust wireless connectivity -
Business value
Maximizes investment flexibility with pay as you go licenses. Self-healing algorithm adapts power and channel of neighboring APs for improved user experience during interference impacted events. Investment protection with support of entry level ProSAFE access points and future proof with 802.11ac access points. Provides complete view of customer deployment environment with heat map, wireless channel, and signal strength for real-time reporting of network status. -
Scalability
Supports up to 50 access points with a single WC7600 and up to 150 access points with a stacks of three WC7600. Supports full line of ProSAFE access points with simplified management and comprehensive monitoring. Supports (N+1) controller redundancy to maximize reliability and minimizes service disruptions. Complete hardware resilience with dual fan tray and hot-swappable power supplies. -
Ease of use
Complete search and sort functions for identification of key wireless statistics and environmental conditions. Simple to use setup for easy access points discovery and configuration managements.
- NETGEAR WC7600v2 Premium Wireless Controller - network management device
- Network management device
- Form Factor
- External
- Localisation
- Worldwide (excluding China, India)
- Ports Qty
- 4
- Data Link Protocol
- Capacity
- Manageable access points: 50 , Maximum number of access points (per cluster): 150 , Virtual interfaces (VLANs): 64 , Security profile groups per profile group: 9 , Detectable rogue access points: 512 , MAC addresses: 512 , Concurrent stations per cluster: 6000 , Concurrent stations per controller: 2000 , BSSIDs: 144
- Power
- AC 100/230 V
- 44 cm x 26.2 cm x 4.3 cm
- 3.6 kg
- NETGEAR lifetime warranty
- Designed For
- NETGEAR Dual Band Wireless-N Access Point WNDAP350, Dual Band Wireless-N Access Point WNDAP360, Premium 3 x 3 Dual Band Wireless-N Access Point WNDAP660, WAC720, WAC730, WAC740 4 x 4, Wireless-N Access Point WNAP320, Wireless-N WNAP210 v2, WN370, WND930; Premium WAC740
- 44 cm
- 26.2 cm
- 4.3 cm
- 3.6 kg
- Localisation
- Form Factor
- External
- Ports Qty
- 4
- Connectivity Technology
- Wired
- DHCP, UDP/IP, TCP/IP, ICMP/IP
- Remote Management Protocol
- SNMP 1, SNMP 2c, HTTP, Telnet, SSH, TFTP
- Capacity
- Status Indicators
- Power, status, fan
- Captive Portal, tagged VLAN, rogue access point detection, load balancing, Access Control List (ACL) support, VLAN support, rate limit, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), DHCP support, Syslog support, Virtual Route Redundancy Protocol (VRRP) support, Management Information Base (MIB), IPv4 support, IPv6 support, Network Timing Protocol (NTP), firmware upgradable, Layer 3 switching, auto-negotiation, auto-sensing per device
- Encryption Algorithm
- DES, Triple DES, IKE, WPA-PSK, WEP, WPA, WPA2-PSK, WPA2-Enterprise, TLS, MD5, AES, PKI, TKIP
- Authentication Method
- Active Directory, X.509 certificates, Radio Service Set ID (SSID), RADIUS, LDAP, TACACS
- IEEE 802.11i, IEEE 802.11e, IEEE 802.3u, IEEE 802.3, IEEE 802.3ab, IEEE 802.1Q, IEEE 802.11n, IEEE 802.11g, IEEE 802.1x
- 4 x 1000Base-T - RJ-45 , 1 x console - DB-9 , 1 x USB 2.0 - Type A
- MTBF
- 664,072 hours
- Voltage Required
- AC 100/230 V
- 13 watt
- Limited warranty - replacement - lifetime - on-site - response time: next business day , Limited warranty - software application support - 90 days , Technical support - lifetime
- 0 °C
- 45 °C
- 10 - 90%
- Designed For
- NETGEAR Dual Band Wireless-N Access Point WNDAP350, Dual Band Wireless-N Access Point WNDAP360, Premium 3 x 3 Dual Band Wireless-N Access Point WNDAP660, WAC720, WAC730, WAC740 4 x 4, Wireless-N Access Point WNAP320, Wireless-N WNAP210 v2, WN370, WND930 , NETGEAR Premium WAC740
