NETGEAR Prosafe 50 Ap Wls Controller
Quicklinx: CZPCWS00 Mfr#: WC7600-20000S
£1,295.50 ex VAT
£1,554.60 inc VAT
The WC7600 premium wireless controller is ideal for K-12 education, hospitality, and healthcare deployments. Designed with simplicity in management and ease of use, it offers enterprise grade functionality and capability for small and midsized organizations, without the cost and complexity of big IT.
  • Performance
    UFast algorithm provides fast and easy access point discovery and firmware management. Fully distributed L2 and L3 roaming enable optimal performance and maximum throughput for seamless mobility. Automatic controls of AP transmit power and channel allocations ensure best coverage by minimizing interferences. Load balancing and rate limiting provide fair bandwidth allocation among all clients for robust wireless connectivity
  • Business value
    Maximizes investment flexibility with pay as you go licenses. Self-healing algorithm adapts power and channel of neighboring APs for improved user experience during interference impacted events. Investment protection with support of entry level ProSAFE access points and future proof with 802.11ac access points. Provides complete view of customer deployment environment with heat map, wireless channel, and signal strength for real-time reporting of network status.
  • Scalability
    Supports up to 50 access points with a single WC7600 and up to 150 access points with a stacks of three WC7600. Supports full line of ProSAFE access points with simplified management and comprehensive monitoring. Supports (N+1) controller redundancy to maximize reliability and minimizes service disruptions. Complete hardware resilience with dual fan tray and hot-swappable power supplies.
  • Ease of use
    Complete search and sort functions for identification of key wireless statistics and environmental conditions. Simple to use setup for easy access points discovery and configuration managements.
NETGEAR WC7600v2 Premium Wireless Controller - network management device
Network management device
External
Worldwide (excluding China, India)
Ports Qty
4
Manageable access points: 50 , Maximum number of access points (per cluster): 150 , Virtual interfaces (VLANs): 64 , Security profile groups per profile group: 9 , Detectable rogue access points: 512 , MAC addresses: 512 , Concurrent stations per cluster: 6000 , Concurrent stations per controller: 2000 , BSSIDs: 144
AC 100/230 V
44 cm x 26.2 cm x 4.3 cm
3.6 kg
NETGEAR lifetime warranty
NETGEAR Dual Band Wireless-N Access Point WNDAP350, Dual Band Wireless-N Access Point WNDAP360, Premium 3 x 3 Dual Band Wireless-N Access Point WNDAP660, WAC720, WAC730, WAC740 4 x 4, Wireless-N Access Point WNAP320, Wireless-N WNAP210 v2, WN370, WND930; Premium WAC740
44 cm
26.2 cm
4.3 cm
3.6 kg
External
Ports Qty
4
Wired
Network / Transport Protocol
TCP/IP, UDP/IP, ICMP/IP, DHCP
Remote Management Protocol
SNMP 1, Telnet, SNMP 2c, HTTP, TFTP, SSH
Status Indicators
Power, status, fan
Layer 3 switching, auto-sensing per device, DHCP support, auto-negotiation, load balancing, VLAN support, Syslog support, IPv6 support, firmware upgradable, Virtual Route Redundancy Protocol (VRRP) support, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, Quality of Service (QoS), IPv4 support, rogue access point detection, Management Information Base (MIB), tagged VLAN, Captive Portal, rate limit, Network Timing Protocol (NTP)
Encryption Algorithm
DES, Triple DES, MD5, AES, IKE, TLS, TKIP, WPA, WPA-PSK, PKI, WPA2-PSK, WPA2-Enterprise, WEP
Authentication Method
RADIUS, X.509 certificates, Radio Service Set ID (SSID), TACACS, LDAP, Active Directory
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e, IEEE 802.11n
4 x 1000Base-T - RJ-45 , 1 x console - DB-9 , 1 x USB 2.0 - Type A
MTBF
664,072 hours
AC 100/230 V
13 Watt
Limited warranty - replacement - lifetime - on-site - response time: next business day , Limited warranty - software application support - 90 days , Technical support - lifetime
45 °C
10 - 90%
NETGEAR Dual Band Wireless-N Access Point WNDAP350, Dual Band Wireless-N Access Point WNDAP360, Premium 3 x 3 Dual Band Wireless-N Access Point WNDAP660, WAC720, WAC730, WAC740 4 x 4, Wireless-N Access Point WNAP320, Wireless-N WNAP210 v2, WN370, WND930 , NETGEAR Premium WAC740
Type: Network management device
Connectivity: Wired
Protocol: Ethernet
Protocol: Gigabit Ethernet
Protocol: Fast Ethernet
Brand: NETGEAR
Price Range Ex VAT: £1000 - £1500
