Brand
NetGear ProSafe 48-Port Gigabit Stackable Smart Switch w/4 10G SFP+
LIFETIME WARRANTY
Quicklinx: 7N4GWS00 Mfr#: GS752TXS-100EUS
Type: Gigabit Ethernet
Ports: 48
Data Transfer Rate: 1Gbps
Managed: Yes
POE: No
£1,152.59 ex VAT
£1,383.10 inc VAT
An ideal companion to the rapidly emerging class of 10-gigabit servers, the NETGEAR ProSafe 52-port gigabit stackable smart switch is the smart switch with 10-gigabit connectivity - delivering maximum throughput in SMB networks for demanding tasks such as data replication and backup, virtualization, video on demand and high-volume transaction processing. At less than half the cost of a managed switch, the ProSafe 52-port gigabit smart switch provides 48 gigabit ports for connecting devices to the network, along with four 10 GE SFP+ ports for stacking or uplink to servers. The GS752TXS offers a rich enterprise-class feature set, including advanced traffic management and security, yet can be easily configured and monitored through a web-based graphical user interface.
With a rich set of Layer 2 management features, the GS752TXS is efficient, secure and ready for the future. Static routing allows for segmentation of the network, with internal routing through the switch - reserving the router for external traffic routing only, making the entire network more efficient. Dynamic VLAN assignment increases security by imposing consistent policy and user credentials across the network, regardless of where users connect. Support for MLD Snooping greatly increase network efficiency by forwarding multicast traffic to designated hosts only, rather than flooding multicast packets across all ports. The GS752TXS also comes with full IPv6 support, comprehensive security and advanced multicast management.
  • Smart switch with 10 G uplinks and stacking
  • Enterprise-class features
  • Scalability and reliability
    The GS752TXS is a scalable solution that grows with a business. Starting with a single switch, the stack can grow to six switches with a total of 288 network ports. Two out of the four 10-gigabit SFP+ ports on each switch can be used to create the stack, a single logical unit with up to 40 Gbps of stacking backplane that can be configured and managed as one switch - speeding up deployment while simplifying administration and maintenance. The stacked switches can be spread across multiple physical locations, by taking advantage of SFP+ fiber-optic connectivity, making the GS752TXS an ideal solution for remote and branch offices. All four 10GE ports can be used for network uplinks to servers and storage devices, or split with two ports for local or distant stacking and two ports for uplinks and link aggregation. Auto failover creates a safety net so that if one switch in the stack fails, all the other switches will be intact.
NETGEAR Smart GS752TXS - switch - 48 ports - Managed
Switch - 48 ports - Managed - stackable
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 4 x 10 Gigabit SFP+
Performance
Bandwidth: 176 Gbps
QoS hardware queues: 8 , Virtual interfaces (VLANs): 256
MAC Address Table Size
16K entries
Routing Protocol
IGMPv2, IGMP, IGMPv3, MLD
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c
Layer 2 switching, VLAN support, IGMP snooping, DoS attack prevention, IPv6 support, SNTP support, DHCP snooping, Quality of Service (QoS), RADIUS support, MLD snooping, LLDP support
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.3aq, IEEE 802.3az
44 cm x 25.7 cm x 4.3 cm
4.5 kg
Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
Performance
Bandwidth: 176 Gbps
16K entries
Max Units In A Stack
6
Routing Protocol
Authentication Method
RADIUS, TACACS+
RAM
128 MB DDR SDRAM
Flash Memory
32 MB
Status Indicators
Power, link/activity, fan
48 x 1000Base-T RJ-45 , 4 x SFP+
Internal power supply
Rack Mounting Kit
Included
C-Tick, EN 60950, EN55022, VCCI Class A ITE, EN55024, FCC Part 15 A
Europe
44 cm
25.7 cm
4.3 cm
4.5 kg
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Ports: 48
Managed: Yes
POE: No
Brand: NETGEAR
Price Range Ex VAT: £1000 - £1500
