NetGear ProSafe 48-Port Gigabit Stackable Smart Switch 2nd Gen
LIFETIME WARRANTY
Quicklinx: 8411WS00 Mfr#: GS752TSB-100EUS
Type: Gigabit Ethernet
Ports: 48
Data Transfer Rate: 1Gbps
Managed: Yes
POE: No
£406.52 ex VAT
£487.82 inc VAT
The ProSafe Gigabit stackable smart switch family is unique in delivering the scalability, reliability, and performance growing small and medium-sized businesses need in an affordable and easy-to-manage package. This stackable smart switch offers more flexibility and scalability that will make it easier and non-interruptive for growing businesses to expand their network capacity.
  • Stacking for scalability and high availability
    The stackable smart switch uses 2 dedicated dual-purpose ports in the front of the switch for stacking or uplink. The stacking function offers a 10 Gbps, dual-ring, highly redundant stacking bus that carries intra-stack traffic and provide the highest level of resilience, forming a virtual chassis for easy management under a single IP address.
  • Comprehensive and advanced feature sets
    This stackable smart switch comes with a complete suite of advanced features for more robust security, higher quality of service and high availability. This switch is equipped with highly advanced features such as access control lists (ACL), static routing, rate limiting, IGMP snooping, and dynamic VLAN assignment among others to provide a small and medium-sized business with a network that is geared for growth and network applications. Friendly to converged network with voice and video, the stackable smart switch offers auto voice and auto video features that automatically configure QoS, security and VLAN settings for IP phones and IP cameras.
  • IPv6 support
    In order to accommodate the move by Internet service providers to IPv6 addresses, the Gigabit stackable smart switch expand the IPv6 support beyond management only to QoS, ACL and multicast. It means that your network will benefit from the IPv6 enhancements and is future-proofed.
NETGEAR Smart GS752TS - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 2 x combo Gigabit SFP + 4 x Gigabit SFP
Virtual interfaces (VLANs): 256
MAC Address Table Size
16K entries
Routing Protocol
IGMPv2, IGMP, IGMPv3, MLD
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP
Flow control, VLAN support, IGMP snooping, DoS attack prevention, port mirroring, Broadcast Storm Control, IPv6 support, full duplex mode, Multicast Storm Control, firmware upgradable, SNTP support, RSTP support, MSTP support, DHCP snooping, QoS, MLD snooping, LLDP support, LACP, DHCP client, Energy Efficient Ethernet, static routing
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3az
AC 120/230 V (50 - 60 Hz)
44 cm x 25.7 cm x 4.3 cm
4.3 kg
Europe
NETGEAR lifetime warranty
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
16K entries
Max Units In A Stack
6
Routing Protocol
RAM
128 MB DDR SDRAM
Flash Memory
32 MB
Status Indicators
Port transmission speed, power, PoE, link/activity, fan
50 x 1000Base-T RJ-45 , 4 x SFP (mini-GBIC)
Internal power supply
77 watt
Rack Mounting Kit
Included
C-Tick, EN 60950, EN55022, VCCI Class A ITE, EN55024, UL 60950, CB, CCC, FCC Part 15 A
Europe
44 cm
25.7 cm
4.3 cm
4.3 kg
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 95% (non-condensing)
8411 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.67
8411 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.82
Ports: 48
Managed: Yes
POE: No
Brand: NETGEAR
