NETGEAR's low-cost, stackable Gigabit Ethernet switches deliver maximum throughput and flexibility where you need it - to high-speed, high-density workgroups at the edge of the network, in the backbone of growing networks or for bandwidth-thirsty file and application servers. The ProSafe GSM7328S fully-managed switch delivers 24 ports of auto-sensing 10/100/1000 Mbps interfaces for high-density copper connectivity.
The ProSafe GSM7328S has two 10 Gigabit Ethernet small form-factor pluggable (SFP+) interfaces and two high-speed, module bays offering modular expansion for 10 Gigabit Ethernet or 48 Gigabit Stacking connectivity. The non-blocking design of the switches delivers simultaneous, full wire-speed, low-latency throughput to all ports.
A full suite of Layer 3 switching functionality ensures reliable routing between VLANs and network segmentation where and when you need it, at no additional cost. By configuring the switches into a stack of up to 8 units across a 48 Gbps bi-directional ring, a high-density, single IP-addressable switch can be built.
Robust security features include IEEE 802.1x port-based authentication and access control lists, ensuring that only authorized users can access your network. Secure management of the switches is available through Secure Sockets Layer (SSLv3) for the Web GUI and Secured Shell (SSH) for command-line sessions or with SNMP v3 for network management software. For workgroup deployments in cost-sensitive organizations that require Layer 3 switching, additional Gigabit capacity, high-value price point, flexibility of stacking, and reduced maintenance requirements, NETGEAR's ProSafe Gigabit Layer 3 Stackable switches deliver the ideal access-edge solution.
With their high-value price point, flexible design, and reduced maintenance requirements, NETGEAR's ProSafe Gigabit Layer 3 Stackable switch solutions yield a high return on investment, and are ideal for delivering highly reliable, converged voice, video, and data services over a single network infrastructure.
Powerful
In desktop switching environments, wire-speed performance with full QoS control for all 10/100/1000 interfaces is critical. The 2 high-speed 10 G/24 G module bays provide unprecedented flexibility, whether you are stacking between switches, attaching bandwidth thirsty file servers, or aggregating critical data to the core of your network. -
Easy to use
Simplify and reduce IT staff workload and mean time-to-repair with intuitive, GUI-based device configuration, and an industry standard command-line interface (CLI). The EZ-Config tool simplifies initial configuration steps to streamline the out-of-box set-up. For easy tracking of port usage, use the text-based port description to label how ports are used. -
Flexible stacking
Stacking capabilities allow you to build a single-IP manageable device with up to eight switches utilizing ultra-high-speed 48 Gbps across intelligent bi-directional redundant stacking links. The stacking link is flexible, in that it can either be a short proprietary copper cable or standard long fiber optic cable. -
Non-stop service
The new rev 2 hardware now comes with a removable power module as the switch's main power supply. In the event of a power supply failure, the switch will change to use the external RPS device for power, and the internal power module can be replaced without an RMA of the entire switch. This will avoid the problem of service disruption or down time due to power supply failure.
- NETGEAR GSM7328Sv2 - switch - 24 ports - Managed
- Switch - 24 ports - L3 - Managed - stackable
- Enclosure Type
- 1U
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000 + 4 x shared Gigabit SFP + 2 x SFP+
- MAC Address Table Size
- 8K entries
- Jumbo Frame Support
- 9KB
- Routing Protocol
- RIP-1, RIP-2, IGMPv2, IGMP, DVMRP, VRRP, OSPFv2, PIM-SM, PIM-DM, IGMPv3, OSPFv3, MLDv2, MLD
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, SSH-2
- Layer 3 switching, Layer 2 switching, auto-sensing per device, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, manageable, store and forward, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, sFlow, DHCP snooping, TFTP support, ACL support, Jumbo Frames support, DHCP server, MLD snooping, DAI
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1v
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 39.1 cm x 4.3 cm
- 6.3 kg
- Localisation
- Europe
- NETGEAR lifetime warranty
- Enclosure Type
- Desktop 1U
- Subtype
- Gigabit Ethernet
- Ports
- 8K entries
- 9KB
- Max Units In A Stack
- 8
- Routing Protocol
- Encryption Algorithm
- TLS 1.0, SSL 3.0
- Authentication Method
- Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
- RAM
- 256 MB
- Flash Memory
- 32 MB Flash
- Status Indicators
- Port transmission speed, power, link OK, Unit ID, status, RPS (Redundant Power Supply), link/activity, fan
- 24 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x RS-232 - 9 pin D-Sub (DB-9) management , 1 x USB Type A , 4 x SFP (mini-GBIC) , 2 x SFP+
- Expansion Slots
- 2 (total) / 2 (free) x Expansion Slot
- Power Device
- Internal power supply
- Voltage Required
- 76.3 Watt
- Redundant Power System (RPS) connector
- Cables Included
- 1 x null modem cable
- Rack Mounting Kit
- Included
- MTBF
- 98,705 hours
- UL, C-Tick, cUL, VCCI Class A ITE, EN55024, EN55022 Class A, CB, CCC, EN 60950-1, FCC Part 15 A
- Localisation
- Europe
- Software Included
- Drivers & Utilities
- 44 cm
- 39.1 cm
- 4.3 cm
- 6.3 kg
- 0 °C
- 50 °C
- 0 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 0 - 95% (non-condensing)
