NETGEAR ProSafe 16-port Gigabit Ethernet Switch
LIFETIME WARRANTY
Quicklinx: 6MDTWS00 Mfr#: JGS516-200EUS
Type: Gigabit Ethernet
Ports: 16
Data Transfer Rate: 1Gbps
Managed: No
POE: [N/A]
£78.09 ex VAT
£93.70 inc VAT
Take Gigabit to the Desktop
NETGEAR’s JGS500 Gigabit Switch Series gives your office network a megaboost of speed and capacity that is within your budget. With up to 48 Gbps of bandwidth, these 16- and 24-port switches can blast 2000 Mbps per port while their affordable prices enable you to put them everywhere. Use it to take Gigabit Ethernet directly to the desktop! Standards-based for easy integration of 10-, 100-, and 1000-Mbps devices, these unmanaged, rack-mountable switches feature 10/100/1000 automatic speed and full/half-duplex sensing plus Auto Uplink on every port. Users can take advantage of the their ability to deliver large amounts of multimedia, image, and video information in no time at all. Ideal for workgroups, labs, departments, or growing offices looking for oustanding performance at a low price.
High Capacity
1000-Mbps speeds and a switching capacity of up to 48 Gbps meet the performance needs for even the most bandwidth-hungry applications. The JGS500 series are perfect for graphics, multimedia, and other applications that have to move large files across the network quickly.
Affordable
Aggressive prices enable your workgroup, department or small network to ramp up to Gigabit speeds, even all the way to the desktop.
Flexible
Each port is equipped with automatic speed and duplex sensing, plus Auto Uplink to adjust for straight-through or crossover cables to make the right link. Standards-based design makes it easy to combine 10-, 100-, and 1000-Mbps devices on your network.
Convenient
Easy to set up and easy to use, these unmanaged switches have per port LED’s for effortless network monitoring. They are compact enough for the desktop but come with a rack-mount kit. They are also compatible with PC, Macintosh, Linux, and Unix operating systems.
  • Efficient cooling system
    Designed to operate within a wide temperature range, this switch ensures reliability from 0°C to 50°C, making it suitable for various environments.
  • High-speed connectivity
    With 16 RJ-45 connectors supporting 1000Base-T, this switch offers high-speed connections, enabling efficient data transfer and network performance.
  • Robust performance
    Features a 32 Gbps switching capacity and an 8K MAC address table size, providing the backbone for a fast, reliable network.
  • Versatile network integration
    Compliant with multiple IEEE standards, including 802.3ab, 802.3i, 802.3u, and 802.3x, ensuring broad compatibility and seamless integration into existing networks.
  • Easy management
    Auto-negotiation, auto-uplink (auto MDI/MDI-X), and flow control features simplify network setup and management, enhancing the user experience.
NETGEAR JGS516v2 - switch - 16 ports - unmanaged - rack-mountable
Switch - 16 ports - unmanaged
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000
Performance
Switching capacity: 32 Gbps
MAC Address Table Size
8K entries
Jumbo Frame Support
9KB
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), QoS, Energy Efficient Ethernet, ToS
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
AC 100/230 V (50 - 60 Hz)
32.8 cm x 16.9 cm x 4.3 cm
1.47 kg
Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000
Performance
8K entries
Jumbo Frame Support
9KB
Status Indicators
Port transmission speed, power, link/activity
16 x 1000Base-T RJ-45
Internal power supply
11.8 Watt
Rack Mounting Kit
Included
MTBF
441,123 hours
Plug and Play, cUL, EN55022, EN55024, CISPR 22, CB, CCC, UL 60950-1, EN 60950-1, KCC, FCC Part 15 A, C-Tick Class A, LVD, VCCI Class A, EAC
Europe
32.8 cm
16.9 cm
4.3 cm
1.47 kg
50 °C
90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
10 - 95%
6MDT C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.67
6MDT C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.82
Ports: 16
Managed: No
POE: [N/A]
Brand: NETGEAR
