NETGEAR ProSAFE 10-port SmartManaged Pro Gigabit PoE+Ethernet Switch
Quicklinx: FSRLWS00 Mfr#: GS110TPP-100EUS
Type: Gigabit Ethernet
Ports: 8
Managed: Yes
POE: PoE+
£148.33 ex VAT
£177.99 inc VAT
The GS110TPP comes with a comprehensive set of features, such as enhanced VLAN and QoS, access control lists (ACL), 802.1x port authentication (MD5), rate limiting and IGMP snooping and many more, to provide businesses with networks that are geared for growth while ensuring performance and reliability. Both an intuitive web-browser GUI interface and smart control center, offer simple management, making it a snap to monitor switch performance, configure ports, even set up port trunks, VLANs, and traffic prioritization. With the fanless design and compact form factor, the GS110TPP offers quiet operation and is suitable for deployments in any type of environment, especially the ones which are sensitive to noise.
  • Enhanced security
    With support for Access Control List (ACL) and both RADIUS and TACACS+ authentication methods, this switch ensures secure network access and management, safeguarding your data from unauthorized access.
  • Robust connectivity
    Featuring 8 PoE+ ports with a total PoE power budget of 120 W and two additional uplink ports, this switch facilitates flexible and efficient power distribution and connectivity for various devices.
  • High performance
    Boasting a non-blocking switching throughput of 20 Gbps and a forwarding performance of 14.8 Mpps, the switch ensures smooth data transmission and high-speed connectivity for all connected devices.
  • Comprehensive network features
    Supports a wide range of networking standards including IEEE 802.1Q VLAN, IEEE 802.1p QoS, and IEEE 802.3ad (LACP), along with advanced features like IPv4/IPv6 routing, IGMP snooping, and VoIP support, making it versatile for any network setup.
  • Easy management and deployment
    Designed for convenience, this switch is cloud managed, allowing for easy setup, configuration, and monitoring from anywhere. Its fanless design ensures silent operation, making it ideal for noise-sensitive environments.
NETGEAR GS110TPP - switch - 8 ports - smart
Switch - 8 ports - smart
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+) + 2 x 10/100/1000 (uplink)
Power Over Ethernet (PoE)
PoE+
PoE Budget
120 W
Performance
Non-blocking switching throughput: 20 Gbps , Forwarding performance (64-byte packet size): 14.8 Mpps
IPv4 routes (static): 32 , Packet buffer size: 512 KB , ACL: 100 , VLANs supported: 64 , IGMP multicast groups: 256
MAC Address Table Size
8K entries
Jumbo Frame Support
10KB
Routing Protocol
IGMPv2, IGMP, IGMPv3, MLD
Remote Management Protocol
SNMP 1, SNMP 2c, SNMP 3, RMON 1, RMON 2, RMON 3, RMON 9, HTTP, HTTPS, IPv4, IPv6
Security slot (Kensington security lock compatible), QoS, fanless, static routing, VLAN support, ACL support, DSCP support, DoS, IGMP snooping, Energy Efficient Ethernet, IPv4 support, IPv6 support, GARP, GVRP, LLDP-MED, LACP support, port trunking, 512KB packet buffer, DHCP snooping, loop prevention, DoS attack prevention, cloud managed, firmware upgradable, store and forward, WRR, SP, VoIP support, flow control, full duplex mode, MSTP support, RSTP support, STP support, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, MLD snooping
IEEE 802.3at, IEEE 802.3af, IEEE 802.1p, IEEE 802.1x, IEEE 802.3az, IEEE 802.1Q, IEEE 802.1D, IEEE 802.1w, IEEE 802.1s, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1ab (LLDP)
23.6 cm x 10.1 cm x 2.7 cm
640 g
Europe
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
120 W
Performance
8K entries
Jumbo Frame Support
10KB
Routing Protocol
Authentication Method
RADIUS, TACACS+
: 500 MHz
RAM
128 MB
Flash Memory
32 MB
Status Indicators
Power, cloud, link/activity/speed, PoE, fault
8 x 10/100/1000 Base-T RJ-45 PoE+ - 30 W , 2 x 10/100/1000 Base-T RJ-45 uplink
External power adapter
Installed Qty
1
MTBF
646,773 hours
Europe
23.6 cm
10.1 cm
2.7 cm
640 g
Limited warranty - lifetime , Limited warranty - power supply - 2 years
95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Ports: 8
Managed: Yes
POE: PoE+
Brand: NETGEAR
