NETGEAR Pro GS310TP 8-port Smart Switch
Quicklinx: F1ZRWS00 Mfr#: GS310TP-100EUS
Type: Gigabit Ethernet
Ports: 8
Data Transfer Rate: [N/A]
Managed: Yes
POE: PoE+
£119.78 ex VAT
£143.73 inc VAT
The NETGEAR S350 series Gigabit PoE+ Ethernet switches provide layer 2 connectivity and high security for voice, video and data convergence.
  • Enhanced connectivity
    With 8 1000Base-T RJ-45 ports offering PoE+ and 2 1000Base-X SFP ports, the NETGEAR Smart GS310TP provides versatile connectivity options for a variety of network needs, ensuring efficient power and data delivery over a single cable.
  • Robust network management
    Manageable via SNMP, the GS310TP switch supports features such as Access Control List (ACL) support, DHCP snooping, and Quality of Service (QoS), enabling precise network control and efficient traffic prioritization.
  • Energy efficient
    Incorporating IEEE 802.3az Energy Efficient Ethernet, this switch reduces power consumption without sacrificing performance, making it an eco-friendly choice for your network infrastructure.
NETGEAR Smart GS310TP - switch - 8 ports - smart
Switch - 8 ports - smart
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+) + 2 x SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
55 W
Routing Protocol
IGMP
Remote Management Protocol
SNMP
VLAN support, IGMP snooping, STP support, DHCP snooping, ACL support, QoS, LACP support, LACP, Energy Efficient Ethernet, security slot (Kensington security lock compatible)
IEEE 802.3ad (LACP), IEEE 802.3az
Middle East, Africa, United Kingdom, Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
55 W
Routing Protocol
IGMP
SNMP
Status Indicators
Power, PoE, link/activity, reset
8 x 1000Base-T RJ-45 PoE+ - 30 W , 2 x 1000Base-X SFP
External power adapter
Limited warranty - replacement - lifetime - response time: next business day , Technical support - phone consulting - 90 days , Technical support - web support
Ports: 8
Managed: Yes
POE: PoE+
Brand: NETGEAR
