The NETGEAR S350 series Gigabit PoE+ Ethernet switches provide layer 2 connectivity and high security for voice, video and data convergence.
Enhanced connectivity
With 8 1000Base-T RJ-45 ports offering PoE+ and 2 1000Base-X SFP ports, the NETGEAR Smart GS310TP provides versatile connectivity options for a variety of network needs, ensuring efficient power and data delivery over a single cable. -
Robust network management
Manageable via SNMP, the GS310TP switch supports features such as Access Control List (ACL) support, DHCP snooping, and Quality of Service (QoS), enabling precise network control and efficient traffic prioritization. -
Energy efficient
Incorporating IEEE 802.3az Energy Efficient Ethernet, this switch reduces power consumption without sacrificing performance, making it an eco-friendly choice for your network infrastructure.
 - NETGEAR Smart GS310TP - switch - 8 ports - smart
 - Switch - 8 ports - smart
- Subtype
 - Gigabit Ethernet
- Ports
 - 8 x 10/100/1000 (PoE+) + 2 x SFP
- Power Over Ethernet (PoE)
 - PoE+
- PoE Budget
 - 55 W
- Routing Protocol
 - IGMP
- Remote Management Protocol
 - SNMP
 - VLAN support, IGMP snooping, STP support, DHCP snooping, ACL support, QoS, LACP support, LACP, Energy Efficient Ethernet, security slot (Kensington security lock compatible)
 - IEEE 802.3ad (LACP), IEEE 802.3az
- Localisation
 - Middle East, Africa, United Kingdom, Europe
 - NETGEAR lifetime warranty
- Enclosure Type
 - Desktop
- Subtype
 - Gigabit Ethernet
- Ports
 - PoE+
- PoE Budget
 - 55 W
- Routing Protocol
 - IGMP
 - SNMP
- Status Indicators
 - Power, PoE, link/activity, reset
 - 8 x 1000Base-T RJ-45 PoE+ - 30 W , 2 x 1000Base-X SFP
- Power Device
 - External power adapter
- Localisation
 - Limited warranty - replacement - lifetime - response time: next business day , Technical support - phone consulting - 90 days , Technical support - web support
