Netgear Powerline 1000 (PL1000)
Extend your wired Internet access to any room in your house using your existing electrical wiring. Just plug the Powerline 1000 into any electrical outlet then plug in your device into the adapter. It's that easy. With its high speed and Homeplug AV2 support, the Powerline 1000 adapter is perfect for connecting smart TVs, streaming players, and game consoles.
Whats in the box?
- NETGEAR Powerline PL1000
- 2 x network cable - 2m
Key Features
- Powerful speed
- Perfect for connecting smart TVs, streaming players and game consoles
- Ideal for HD streaming and lag-free gaming
- Pick-a-plug LED for high performance
- Sets up in minutes, no need to install software
- Secures the network connection with the touch of a button
- Energy saving - powers down when not connected
Product Features
- Get connected with Powerline - NETGEAR Powerline is an easy way to extend a wired Internet connection to any room without running long wires. Just plug into any electrical outlet and connect your device to the Ethernet port. It's that easy.
- Reliable networking - Connect multiple adapters to expand your wired network reliably.
- Advanced technology - Homeplug AV2 support for Gigabit speeds through your electrical outlets for improved coverage.
- Plug-and-play - Setup in minutes, no need to configure or install software.
- Energy-saving - Automatically powers down when not in use.
- Push-and-secure - Encrypts Powerline network connections with the touch of a button.
- NETGEAR Powerline PL1000 - powerline adapter kit - wall-pluggable
- Powerline adapter kit
- Packaged Quantity
- 2 (specifications are for single item)
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV) 2.0
- Data Transfer Rate
- 1 Gbps
- IEEE 802.3, HomePlug AV 2.0, IEEE 1901
- Power
- AC 120/230 V
- 5.9 cm x 3.59 cm x 10 cm
- 126 g
- System Requirements
- Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8
- Localisation
- United Kingdom
- 1-year warranty
- Packaged Quantity
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wired
- 1 Gbps
- 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x HomePlug AV 2.0
- Power Device
- Internal power supply
- Voltage Required
- AC 120/230 V
- 5 Watt
- Cables Included
- 2 x network cable - 2 m
- Localisation
- United Kingdom
- OS Required
- 5.9 cm
- 3.59 cm
- 10 cm
- 126 g
- Limited warranty - 1 year , Technical support - 90 days
