Meet Orbi – Fast, Secure, Whole Home WiFi
Orbi is the World’s First Tri-band WiFi System. From your front yard to your home office to your pool, Orbi gives you reliable, secure, and crazy fast WiFi to every inch of your home.
WiFi Everywhere
No more dead zones upstairs, no dropped connections through walls, just WiFi everywhere. The Orbi Home WiFi System reaches up to 4,000 square feet through WiFi barriers like walls, stairs and doors. Need more coverage? Just add an Orbi Satellite to instantly expand your WiFi reach.
Don’t Wait on Buffering
Buffering shouldn’t be a part of family movie night. Orbi helps prevent buffering and lag by creating a high speed Internet superhighway for all of your devices. The Orbi Tri-band WiFi System works with your current ISP’s modem to maximize the speed you are paying for.
Quick and Easy Setup
Unlike some WiFi systems, Orbi works with your Internet service provider right out of the box. You won’t need to change your current equipment to use the Orbi WiFi Home System. Orbi uses a single WiFi name (SSID) and with just a couple of clicks, your secure WiFi network will be ready in no time.
Routers. Not Just for Squares Anymore
Orbi’s sleek design and state-of-the-art technology steals the show. It gives your home a superior WiFi network that is both easy to setup and elegant to display.
Better Wi-Fi everywhere
Take your Wi-Fi device from room to room and Orbi follows with fast Wi-Fi speeds. -
Max Internet speeds
Orbi uses Tri-band Wi-Fi to keep your Internet running at max speeds no matter how many devices connect. -
Just plug in
With simple setup from your mobile device, your secure Wi-Fi network is ready in just minutes.
- NETGEAR Orbi WiFi System RBK50 - Wi-Fi system - Wi-Fi 5 - desktop
- Wi-Fi system - mesh
- Enclosure Type
- Desktop
- Wi-Fi System Components
- Router, extender
- Wi-Fi System Coverage
- Up to 5,000 sq.ft
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz (1 band) / 5 GHz (2 bands) / 5 GHz (3 bands)
- Intelligent Assistant
- Alexa
- MU-MIMO technology, beamforming technology, guest access, Circle Smart Parental Controls
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- 16.3 cm x 7.87 cm x 20.3 cm
- 889 g
- Wi-Fi system - mesh - 3-port switch (integrated)
- Router, extender
- Up to 5,000 sq.ft
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- Encryption Algorithm
- WPA2-PSK
- Wi-Fi Rating
- AC3000
- Mesh Networking
- RAM
- 512 MB
- Flash Memory
- 4 GB
Line Properties
- Line Coding Format
- 256 QAM
Internet of Things (IoT)
- Alexa
- WAN: 1 x 1000Base-T - RJ-45 , LAN: 3 x 1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
- Aerial
- Internal
- Power Device
- External power adapter
- Cables Included
- 1 x network cable - 2 m
- 16.3 cm
- 7.87 cm
- 20.3 cm
- 889 g
