NETGEAR Orbi Pro Kit (Rout+Satellite)
Quicklinx: D9RFWS00 Mfr#: SRK60-100UKS
Type: Wi-Fi system
Connection Type: WAN/LAN
Standards: Gigabit Ethernet, IEEE 802.11g, IEEE 802.11n, IEEE 802.11b + 4 more
Rackmount or External: Desktop
  • IEEE 802.11n
£413.03 ex VAT
£495.63 inc VAT
From the lobby to the storage room, Orbi Pro Tri-Band Wi-Fi System (SRK60) covers up to 5,000 square feet with high-performance AC3000 (3Gbps) Wi-Fi. First with innovative Tri-band Wi-Fi, Orbi Pro helps deliver the fastest available Internet speeds as more devices connect. This Orbi Pro Wi-Fi system comes with an Orbi Pro Wi-Fi router and satellite and replaces your business router. It also easily works with existing business service provider equipment so you will enjoy better Wi-Fi everywhere in your business.
  • Fast business Wi-Fi everywhere
  • Ethernet ports
    Use the Ethernet ports on the router and the satellite to connect your point of sale, printer, IP phones and more.
  • Traffic separation
    Up to 3 Wi-Fi Internet networks (SSID) with traffic separation to define 3 dedicated and completely isolated Wi-Fi networks inside your company securely. SSID management is easily done through the Orbi app for instant setup.
NETGEAR Orbi Pro SRK60 - Wi-Fi system - Wi-Fi 5 - desktop, wall-mountable, ceiling-mountable
Wi-Fi system
Enclosure Type
Desktop, wall-mountable, ceiling-mountable
Wi-Fi System Components
Router, extender
Wi-Fi System Coverage
Up to 5,000 sq.ft
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz (1 band) / 5 GHz (2 bands)
Captive Portal, MU-MIMO technology, beamforming technology, Tri-Band, guest access
17.3 cm x 8.38 cm x 24.6 cm
934 g
Wi-Fi system - 7-port switch (integrated)
Router, extender
Up to 5,000 sq.ft
Enclosure Type
Wireless, wired
Frequency Band
Encryption Algorithm
WPA, WPA2-PSK
Wi-Fi Rating
AC3000
Line Properties
Line Coding Format
256 QAM
WAN: 1 x 1000Base-T - RJ-45 , LAN: 3 x 1000Base-T - RJ-45 , LAN: 4 x 1000Base-T - RJ-45 - on extender
Aerial
Aerial
Internal
Antenna Qty
6
External power adapter
Installed Qty
2
2 x wall mounting kits, 2 x ceiling mounting kits
1 x network cable - 2 m
17.3 cm
8.38 cm
24.6 cm
934 g
Type: Wi-Fi system
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Standards: IEEE 802.11b
Standards: Ethernet
Standards: Fast Ethernet
Standards: IEEE 802.11a
Standards: IEEE 802.11ac
Brand: NETGEAR
