NETGEAR Nighthawk SX10 Pro Gaming 8-port Switch
Quicklinx: D7YHWS00 Mfr#: GS810EMX-100UKS
Type: Gigabit Ethernet
Ports: 8
Managed: Yes
£177.19 ex VAT
£212.62 inc VAT
NETGEAR Nighthawk Pro Gaming brings versatile and limitless gaming with SX10 8-port Switch with 2x 10G/Multi-Gig Uplinks. Get close to zero latency, precision driven auto-diagnostics and a new gaming dashboard. Its sleek design and one-click configurations will impress your fellow gamers at LAN parties. Unleash your speeds potential.
  • Unlock high speeds with 10G
    10G is 10x faster than 1G. Support multi-gig devices with the power they deserve.
  • Powerful & intuitive gaming dashboard
    Control latency and reduce lag spikes. Optimized for gaming, limit bandwidth access per device with just a click.
  • Fully customizable RGB LED controls
    Personalize every LED for better visibility or match your gaming set-up.
  • One-click set-up
    Mobile-optimized GUI and "One-click" per-configured settings for all media needs.
  • Sleek design
    100% Premium Aluminum housing for durability and looks.
NETGEAR Nighthawk Pro Gaming SX10 - switch - 8 ports
Switch - 8 ports
Subtype
Gigabit Ethernet
Ports
8 x 1000Base-T + 2 x 100/1000/2.5G/5G/10G (uplink)
Performance
Bandwidth: 56 Gbps , Forwarding performance (64-byte packet size): 41.664 Mfps
Priority queues: 8 , IGMP multicast groups: 128
MAC Address Table Size
16K entries
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
HTTP
Flow control, IGMP snooping, port mirroring, store and forward, firmware upgradable, Quality of Service (QoS), Link Aggregation Control Protocol (LACP), DHCP client, Energy Efficient Ethernet, 2MB packet buffer, 4K resolution support, Class of Service (CoS), DiffServ Code Point (DSCP) support, administrator's password, LED on/off button, Weighted Round Robin (WRR), VLAN Tagging
IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3an, IEEE 802.3az, IEEE 802.3bz
26.8 cm x 20.3 cm x 9.3 cm
1.515 kg
United Kingdom
3-year warranty
Switch - 8 ports
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Routing Protocol
HTTP
Status Indicators
Status
8 x 1000Base-T RJ-45 , 2 x 100/1000/2.5G/5G/10GBase-T RJ-45 uplink
External power adapter
14.19 Watt
CB, LVD, EAC
United Kingdom
26.8 cm
20.3 cm
9.3 cm
1.515 kg
Limited warranty - 3 years
90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
95% (non-condensing)
Ports: 8
Managed: Yes
Brand: NETGEAR
Price Range Ex VAT: 150 - 300
