NETGEAR Nighthawk Pro Gaming brings versatile and limitless gaming with SX10 8-port Switch with 2x 10G/Multi-Gig Uplinks. Get close to zero latency, precision driven auto-diagnostics and a new gaming dashboard. Its sleek design and one-click configurations will impress your fellow gamers at LAN parties. Unleash your speeds potential.
Unlock high speeds with 10G
10G is 10x faster than 1G. Support multi-gig devices with the power they deserve. -
Powerful & intuitive gaming dashboard
Control latency and reduce lag spikes. Optimized for gaming, limit bandwidth access per device with just a click. -
Fully customizable RGB LED controls
Personalize every LED for better visibility or match your gaming set-up. -
One-click set-up
Mobile-optimized GUI and "One-click" per-configured settings for all media needs. -
Sleek design
100% Premium Aluminum housing for durability and looks.
 - NETGEAR Plus SX10 - switch - 8 ports
 - Switch - 8 ports
- Subtype
 - Gigabit Ethernet
- Ports
 - 8 x 1000Base-T + 2 x 100/1000/2.5G/5G/10G (uplink)
- Performance
 - Bandwidth: 56 Gbps , Forwarding performance (64-byte packet size): 41.664 Mfps
- Capacity
 - Priority queues: 8 , IGMP multicast groups: 128
- MAC Address Table Size
 - 16K entries
- Routing Protocol
 - IGMPv2, IGMP, IGMPv3
- Remote Management Protocol
 - HTTP
 - Flow control, IGMP snooping, port mirroring, store and forward, firmware upgradable, Quality of Service (QoS), Link Aggregation Control Protocol (LACP), DHCP client, Energy Efficient Ethernet, 2MB packet buffer, 4K resolution support, Class of Service (CoS), DiffServ Code Point (DSCP) support, administrator's password, LED on/off button, Weighted Round Robin (WRR), VLAN Tagging
 - IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3an, IEEE 802.3az, IEEE 802.3bz
 - 26.8 cm x 20.3 cm x 9.3 cm
 - 1.515 kg
- Localisation
 - United Kingdom
 - 3-year warranty
 - Switch - 8 ports
- Enclosure Type
 - Desktop
- Subtype
 - Gigabit Ethernet
- Ports
- Performance
- Capacity
 - 16K entries
- Routing Protocol
 - HTTP
- Status Indicators
 - Status
 - 8 x 1000Base-T RJ-45 , 2 x 100/1000/2.5G/5G/10GBase-T RJ-45 uplink
- Power Device
 - External power adapter
 - 14.19 Watt
 - CB, LVD, EAC
- Localisation
 - United Kingdom
 - 26.8 cm
 - 20.3 cm
 - 9.3 cm
 - 1.515 kg
 - Limited warranty - 3 years
 - 0 °C
 - 40 °C
 - 90% (non-condensing)
- Min Storage Temperature
 - -40 °C
- Max Storage Temperature
 - 70 °C
- Humidity Range Storage
 - 95% (non-condensing)
