Fast speed for downloading, streaming and media sharing - everything you do at home can now be done virtually anywhere you go.
Super-Fast mobile broadband Internet
Get incredible download speeds of up to 1 Gbps and upload speeds of up to 150 Mbps. -
Category 16 LTE
Support for 4GX LTE Advanced Category 16 with 4-band carrier aggregation. -
Always-on connection
Never be without Wifi. Connect up to 20 devices on the go. -
Media streaming
Stream media from a USB or external hard drive to all your connected devices. -
Compatible with major service providers
An unlocked device will accept all SIM cards. Works best on AT&T and T-Mobile networks. -
Offloading capabilities
Offload to Wifi or Ethernet to relieve network congestion
- NETGEAR Nighthawk M1 Mobile Router - mobile hotspot - 4G LTE Advanced
- Mobile hotspot
- Form Factor
- External
- Localisation
- Europe
- Max Transfer Rate
- 1 Gbps
- Mobile Communication Protocol
- LTE Advanced
- Networking
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Battery
- 5040 mAh
- 10.55 cm x 10.55 cm x 2.035 cm
- 240 g
- Specific Absorption Rate (SAR)
- 1.96 W/kg
- Mobile hotspot
- Form Factor
- External
- Built-in Devices
- NAS server, 2.4" display
- Localisation
- Europe
Modem
- Connectivity Technology
- Wireless
- Processor
- Qualcomm MDM9x50
- Max Transfer Rate
- 1 Gbps
- LTE Advanced
- Wireless
- Data Link Protocol
- Parental control, DLNA Media Server, 4T4R MIMO technology, dual band
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Supported Flash Memory Cards
- microSD
- 1 x 1000Base-T - RJ-45 , 1 x USB - Type C , 2 x aerial - TS-9 , 1 x USB 2.0 - Type A
- SIM Card Supported
- Micro-SIM x 1
- Cables Included
- 1 x USB cable
- Included Accessories
- Power adapter
- 1.96 W/kg
- Battery
- Lithium Ion
- Capacity
- 5040 mAh
- 10.55 cm
- 10.55 cm
- 2.035 cm
- 240 g
