Secure, private WiFi connection for laptops, tablets & phones in airports, hotels, trains
NEW : Ultra-fast, secure 5G internet up to 4Gbps‡. Perfect for work & play when traveling
NEW : WiFi 6E speeds up to 3.6Gbps8 for up to 32 devices for fast downloads, streaming & gaming and the latest WiFi 6E-ready laptops, phones, & tablets
NEW : 2.5 Gig Ethernet port for multi-gig wired speeds to laptops or home WiFi routers
Unlocked and supports international roaming across 125 countries1 so you can enjoy the freedom to pick the carrier, SIM card, and data plan that fit your needs.
Boost WiFi coverage up to 1,000 sq. ft. at home†. Remove the battery & use the power adapter
Long lasting battery for up to 13 hours on a single charge*
5G network for home internet
If Fibre, DSL, or cable internet speeds are not optimal in your area, use the mobile network as your primary Internet connection. Simply connect your 5G Mobile Router to your existing home router or mesh system via the Ethernet port, or pair wirelessly with a mesh extender to deliver 5G speeds into your home network, and all your devices. -
Super-fast 5G speeds
5G delivers blazing-fast speeds so you can stream, browse, download, and more without slowdown. -
WiFi 6
With increased capacity, enjoy faster speeds for simultaneous high-end video streaming on up to 32 WiFi devices. -
Fixed wireless options
If wired internet is not optimal in your area, use 5G as the primary internet connection for all your devices at home or the office. -
Secure and reliable network
Avoid the dangers of connecting to public WiFi. The Nighthawk M5 is equipped with VPN pass-through support and password protection. -
Flexible battery operation
Stay connected for up to 13 hours on a single charge - or remove the battery and plug into the wall for all-day use. -
Simple control via the app
With the NETGEAR mobile app, you can offload to WiFi or Ethernet, track data usage by month and session, manage guest WiFi, and customize WiFi settings.
- NETGEAR Nighthawk M5 Mobile Router (MR5200) - mobile hotspot - 5G LTE Advanced
- Mobile hotspot
- Form Factor
- External
- Localisation
- Europe
- Max Transfer Rate
- 4 Gbps
- Line Coding Format
- 256 QAM, 1024 QAM
- Mobile Communication Protocol
- LTE Advanced, 5G NR
- Networking
- 802.11ax, Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- 10.5 cm x 10.5 cm x 2.15 cm
- 240 g
- 1-year warranty
- Mobile hotspot
- Form Factor
- External
- Built-in Devices
- 2.4" touch screen display
- Localisation
- Europe
Modem
- Connectivity Technology
- Wireless
- Processor
- Qualcomm SDx55
- Max Transfer Rate
- 4 Gbps
- 256 QAM, 1024 QAM
- Wireless
- Data Link Protocol
- IPv6 support, beamforming technology, SU-MIMO technology, BSS Coloring
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6
- 1 x 1000Base-T - RJ-45 , 1 x USB 3.1 Gen 2
- Limited warranty - 1 year , Technical support - 90 days
- 10.5 cm
- 10.5 cm
- 2.15 cm
- 240 g
NETGEAR Nighthawk M5 MR5200 WiFi 6 5G Mobile Hotspot Router
