NETGEAR Nighthawk EAX80 Wi-Fi 6 Mesh Range Extender
Quicklinx: GCZ9WS00 Mfr#: EAX80-100EUS
Type: Wi-Fi range extender
Connectivity: Wireless
Speed: [N/A]
Protocol: Ethernet, IEEE 802.11a, Fast Ethernet, IEEE 802.11b + 5 more
Compatibility: [N/A]
  • IEEE 802.11n
£298.88 ex VAT
£358.65 inc VAT
The NETGEAR Nighthawk AX8 8-Stream Mesh Extender (EAX80) supports the latest generation WiFi 6 (802.11ax) standard. This powerful Nighthawk Mesh Extender works with your existing WiFi to create a powerful whole home mesh WiFi system. Enjoy a better connected home experience and extend faster WiFi to the farthest corners of your home with blazing fast speeds up to 6 Gbps.WiFi.
  • WiFi 6 (802.11ax) standard
    This Nighthawk Mesh Extender works with your existing WiFi to create a powerful whole home mesh WiFi. Ideal for extending coverage to the farthest corner of your home with dramatically faster WiFi to devices such as your smartphones, tablets, and computers.
  • Gigabit speeds to your mobile devices
    AX6000 WiFi with combined speeds up to 6Gbps (4.8+1.2Gbps) extend Gigabit speeds throughout your home.
  • 8-stream WiFi
    More streams provide more available bandwidth and less congestion for all the devices on your WiFi network.
  • Expansive coverage for the smart home
    Creates a powerful mesh network with wider range to cover every corner of your home even where your router WiFi cannot reach. Get better coverage for your outdoor wireless security cameras or your garage.
  • Works with your existing WiFi router
    Compatible with the previous generation WiFi routers (WiFi 5, WiFi 4 routers). Maximum performance with the Nighthawk WiFi 6 routers. Easily creates a whole home mesh WiFi system with your existing router.
  • Greater capacity for more devices
    Orthogonal Frequency-Division Multiple Access (OFDMA) substantially improves the network capacity and efficiency. Facilitates efficient data transmission for more devices simultaneously enables Gigabit WiFi speeds for compatible mobile devices and laptops. Up to 2 times faster than standard 2x2 AC WiFi with 80MHz.
  • Smart roaming
    Automatically connects your mobile devices to the best available WiFi for superior streaming as you move around your house.
  • One WiFi name
    Extend coverage of your home's WiFi with same WiFi name and security password.
  • Four Gigabit Ethernet ports
    Enjoy Gigabit speeds for unparalleled gaming and streaming performance to your wired devices.
  • Multi-user MIMO (MU-MIMO)
    Enables simultaneously streaming to multiple devices, and improves capacity for wireless connections.
  • Works with existing WiFi devices
    Supports current WiFi devices and is backward compatible with WiFi 5 (802.11ac), WiFi 4 (802.11n) and earlier generation WiFi standards.
  • Dual-core processor
    Boosts performance for better 4K streaming and lag-free gaming.
NETGEAR Nighthawk AX8 EAX80 - Wi-Fi range extender - Wi-Fi 6
External
1.8 GHz
Ports Qty
4
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 802.11ax
Frequency Band
2.4 GHz, 5 GHz
27.9 cm x 19.7 cm x 10.6 cm
860 g
1-year warranty
27.9 cm
19.7 cm
10.6 cm
860 g
Processor / Memory / Storage
Processors Installed
1.8 GHz
External
Ports Qty
4
Wireless
Line Coding Format
256 QAM, 1024 QAM
Network / Transport Protocol
IPv6
Remote Management Protocol
IPv6
Frequency Band
2.4 GHz, 5 GHz
Wi-Fi Rating
AX6000
Auto-sensing per device, Mesh networking, ReadySHARE, reset button, Beamforming+, Smart Connect, 4x4 MU-MIMO technology, Smart Roaming, Orthogonal Frequency Division Multiple Access (OFDMA), 4K HD video streaming, 8K HD video streaming
Encryption Algorithm
128-bit AES
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11i, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6
Aerial
Antenna
Internal
Antenna Qty
4
4 x 1000Base-T - RJ-45 , 1 x USB 3.0 - Type A
External power adapter
OS Provided
No operating system
Limited warranty - 1 year
Speed: [N/A]
Protocol: Ethernet
Protocol: IEEE 802.11a
Protocol: Fast Ethernet
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11n
Protocol: Gigabit Ethernet
Protocol: 802.11ax
Antennas: 4
Brand: NETGEAR
