NETGEAR Nighthawk EAX20 Wi-Fi 6 Mesh Range Extender
Quicklinx: GCZ8WS00 Mfr#: EAX20-100EUS
  • IEEE 802.11n
£153.06 ex VAT
£183.67 inc VAT
The NETGEAR AX1800 4-Stream Mesh Extender (EAX20) supports the Wi-Fi 6 (802.11ax) standard. This powerful mesh extender is built for the future of Wi-Fi delivering great capacity, fast speed and more coverage. Enjoy a better connected home experience and extend faster Wi-Fi to the farthest corner of your home with speeds up to 1.8Gbps. With 4-stream Wi-Fi, more spatial streams provide more available bandwidth and less congestion for all the devices in the Wi-Fi network. Ideal for small to medium-sized homes with up to four bedrooms, you can extend powerful Wi-Fi to every corner and take advantage of fast broadband speeds to get the speeds you pay for. Upgrade to a Wi-Fi 6 Mesh Extender to experience faster Wi-Fi speeds and up to 1.5 times greater network capacity than Wi-Fi 5, so you can connect more and more devices on your Wi-Fi today and tomorrow without worry.
  • Easily create a mesh Wi-Fi 6 system with your existing router
    Expand coverage of your existing router using your current Wi-Fi name and password. This desktop design has two powerful internal antennas that extend Wi-Fi signals to where your router Wi-Fi cannot reach. This AXE1800 mesh extender is backward compatible with previous Wi-Fi generations (11b/g/n/a/ac) and will work with all your existing internet-connected devices.
  • Great speed and range without bandwidth drop
    Your upgraded Wi-Fi experience will deliver smooth streaming of ultra HD content on your new smart TV, music for your Wi-Fi connected speakers, and fast online game play throughout your home.
  • No more switching Wi-Fi network names
    The AXE1800 4-Stream Mesh Extender creates a seamless network throughout your home by using the same Wi-Fi network name (SSID) as your router. Your Wi-Fi devices like the smartphones and laptops will remain connected to the same network name without disconnect and reconnect as you move around your house and yard.
  • Seamless coverage for your mobile devices
    Smart Roaming intelligently connects your mobile devices to the optimal Wi-Fi for 4K streaming, surfing and more. Now you can enjoy uninterrupted streaming on YouTube or Netflix, even as you move around the house.
  • Four Gigabit Ethernet ports: connect more
    A desktop extender like EAXE20 is a great choice if you need more Ethernet ports to connect network-ready wired devices. Use the extender's four Gigabit Ethernet ports to connect wired devices like Smart TVs and game consoles.
NETGEAR EAX20 - Wi-Fi range extender - Wi-Fi 6
External
Europe
1.5 GHz
Ports Qty
4
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 802.11ax
Frequency Band
2.4 GHz, 5 GHz
24.17 cm x 16.95 cm x 6.34 cm
504 g
1-year warranty
24.17 cm
16.95 cm
6.34 cm
504 g
Europe
Processor / Memory / Storage
Processors Installed
1.5 GHz
External
Ports Qty
4
Wireless
Line Coding Format
1024 QAM
Frequency Band
2.4 GHz, 5 GHz
Wi-Fi Rating
AX1800
Auto-sensing per device, Mesh networking, Wi-Fi Protected Setup (WPS), Push ā€˜N’ Connect button, reset button, dual band, 4x4 MU-MIMO technology, Orthogonal Frequency Division Multiple Access (OFDMA), 4K HD video streaming
Encryption Algorithm
128-bit AES
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11i, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6
Aerial
Antenna
Internal
4 x 1000Base-T - RJ-45
External power adapter
Limited warranty - 1 year , Technical support - 90 days - response time: 24 hours
Type: Wi-Fi range extender
Connectivity: Wireless
Speed: 1.8Gbps
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Protocol: Gigabit Ethernet
Protocol: Fast Ethernet
Protocol: Ethernet
Protocol: IEEE 802.11b
Protocol: 802.11ax
Brand: NETGEAR
