NETGEAR Nighthawk AX6600 (RAX70) Wi-Fi 6 Router
Quicklinx: GCZJWS00 Mfr#: RAX70-100EUS
Type: Wireless router
Connection Type: WAN/LAN
Standards: Gigabit Ethernet, IEEE 802.11a, Fast Ethernet, IEEE 802.11g + 5 more
Speed: 600Mbps
Rackmount or External: Desktop
  • IEEE 802.11n
£179.46 ex VAT
£215.35 inc VAT
8 Wi-Fi streams offer four times the device capacity that typical 2x2 AC Wi-Fi does. More Wi-Fi streams more bandwidth availability and less congestion. Now, more devices than ever before can reliably and simultaneously connect to your network.
  • Wi-Fi 6 technology
    Wi-Fi 6 technology helps deliver the fast speeds to all your connected devices of today and tomorrow with 4x more capacity, and is 100% backwards compatible.
  • Gigabit Wi-Fi to mobile devices
    Support for WAN port aggregation lets you stream your favorite TV shows and movies in high definition on more devices.
  • Better network capacity
    Efficient data scheduling creates an impressive capacity increase that allows more devices to be connected to your network.
  • Powerful performance at the core
    A 1.5 GHz quad-core processor powers Nighthawk AX8, transferring gigabits of data with almost zero CPU load so you always get the perfect performance for streaming, gaming, and more without interruptions.
NETGEAR RAX70 - wireless router - Wi-Fi 6 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6)
Frequency Band
2.4 GHz (1 band) / 5 GHz (2 bands)
Streams: 8
Network / Transport Protocol
IPv6
NAT support, VPN support, DFS support, firmware upgradable, reset button, Beamforming+, MU-MIMO technology, Dynamic QoS, 4K UHD video streaming, 160MHz bandwidth support
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11i, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6
34.7 cm x 20.8 cm x 16.5 cm
1.171 kg
Europe
1-year warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
Streams: 8
IPv6
Encryption Algorithm
WPA-PSK, 128-bit AES, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
Wi-Fi Rating
AX6600
1.5 GHz
RAM
512 MB
Flash Memory
256 MB
Status Indicators
Status
Line Properties
Line Coding Format
256 QAM, 1024 QAM, OFDMA
WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A
Europe
34.7 cm
20.8 cm
16.5 cm
1.171 kg
Limited warranty - 1 year , Technical support - 90 days
Standards: IEEE 802.11a
Standards: Fast Ethernet
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Standards: Ethernet
Standards: IEEE 802.11b
Standards: IEEE 802.11ax (Wi-Fi 6)
Standards: IEEE 802.11ac
Speed: 600Mbps
Brand: NETGEAR
