NETGEAR Nighthawk AX1800 (RAX10) 4-Stream Wi-Fi 6 Router
Quicklinx: GCZFWS00 Mfr#: RAX10-100EUS
Type: Wireless router
Connection Type: WAN/LAN
Standards: Gigabit Ethernet, IEEE 802.11g, IEEE 802.11b, Ethernet + 5 more
Speed: 1.8Gbps
Rackmount or External: Desktop
  • IEEE 802.11n
£114.32 ex VAT
£137.18 inc VAT
The NETGEAR 4-Stream AX1800 Wi-Fi 6 Router upgrades your network to provide greater capacity with consistent and powerful signal strength to all your connected devices. Powerful quad-core 1.5GHz processor ensures superior performance for concurrent realtime applications such as multimedia streaming, online gaming and audio/video chats.
  • Enhanced connectivity
    With a comprehensive combination of Ethernet 10Base-T/100Base-TX/1000Base-T interfaces and four external antennas, this router ensures extensive coverage and high-speed Internet connectivity. Its integrated 4-port switch allows for seamless connection of multiple devices.
  • Advanced security
    Equipped with 128-bit AES encryption and WPA3, the most advanced Wi-Fi security protocol, this router offers a secure and private Internet experience, protecting your network from potential threats.
  • Optimized for streaming
    Supporting 4K UHD video streaming and featuring Wi-Fi 6 technology, the router delivers a smooth, lag-free viewing experience, making it ideal for streaming your favorite movies and shows in high definition.
  • Voice control enabled
    Compatibility with intelligent assistants like Alexa and Google Assistant allows for easy voice control, offering a convenient way to manage your network settings.
  • High performance
    A 1.5 GHz processor coupled with 512 MB of RAM ensures efficient data processing and handling of multiple simultaneous connections, providing a reliable and fast Internet experience for all connected devices.
NETGEAR RAX10 - wireless router - Wi-Fi 6 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6)
Frequency Band
2.4 GHz / 5 GHz
Streams: 4
Intelligent Assistant
Google Assistant, Alexa
VPN support, firmware upgradable, reset button, guest access, NETGEAR Armor, Voice Control, 4K UHD video streaming
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11i, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6
23.6 cm x 18.4 cm x 5.7 cm
500 g
UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8/10
Europe
1-year warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Streams: 4
Encryption Algorithm
128-bit AES, WPA3
Wi-Fi Rating
AX1800
1.5 GHz
RAM
512 MB
Flash Memory
256 MB
Line Properties
Line Coding Format
256 QAM, 1024 QAM
Internet of Things (IoT)
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
Aerial
External
Antenna Qty
4
External power adapter
1 x network cable
Europe
OS Provided
No operating system
23.6 cm
18.4 cm
5.7 cm
500 g
Limited warranty - 1 year , Technical support - 90 days
Standards: IEEE 802.11g
Standards: IEEE 802.11b
Standards: Ethernet
Standards: IEEE 802.11a
Standards: Fast Ethernet
Standards: IEEE 802.11n
Standards: IEEE 802.11ac
Standards: IEEE 802.11ax (Wi-Fi 6)
Speed: 1.8Gbps
Brand: NETGEAR
