NETGEAR Nighthawk AX1100 (RAX200) Wi-Fi 6 Router
Quicklinx: GCZLWS00 Mfr#: RAX200-100EUS
Type: Wireless router
Connection Type: WAN/LAN
Standards: Fast Ethernet, IEEE 802.11a, Ethernet, IEEE 802.11b + 6 more
Speed: 5.3Gbps
Rackmount or External: External
  • IEEE 802.11n
£417.82 ex VAT
£501.38 inc VAT
Nighthawk Tri-Band AX12 RAX200 WiFi Router is powered by the industry's latest WiFi 6 (802.11ax) standard with 4 times increased data capacities to handle more devices on your network. Blazing-fast combined WiFi speeds up to 10.8Gbps and AX optimized 1.8GHz quad-core processor powers smart home applications, multiple 4K/8K streaming, low latency gaming, and more.
  • Faster speeds
    Get ultra-fast wireless speeds for better streaming, gaming or video conferencing experience.
  • Better capacity
    Get better performance for all your smart home devices even when your family is busy streaming videos or uploading media files during the Internet rush hour.
  • Expanded Wi-Fi range
    Faster and expanded coverage throughout your home and for all your devices.
  • Reliable technology
    There's nothing more frustrating than lost connexions! With NETGEAR's advanced features & superior technology, you'll reduce interference & enjoy more reliable Wi-Fi connectivity.
  • Easy to use
    Start enjoying your device faster than ever. NETGEAR wants to make sure instalation and management is simple & easy, so you can connect quickly & make sure you stay that way.
NETGEAR Nighthawk RAX200 - wireless router - Wi-Fi 6
Wireless router - 5-port switch (integrated)
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 2.5 Gigabit Ethernet, IEEE 802.11ax (Wi-Fi 6)
Frequency Band
2.4 GHz (1 band) / 5 GHz (2 bands)
Streams: 12
Intelligent Assistant
Google Assistant, Alexa
VPN support, firmware upgradable, reset button, Beamforming+, MU-MIMO technology, Link Aggregation, LED on/off button, guest access, Circle Smart Parental Controls
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11i, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6
29.5 cm x 22.7 cm x 5.44 cm
1.1 kg
UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8/10
Europe
1-year warranty
Wireless, wired
Frequency Band
Streams: 12
Encryption Algorithm
128-bit AES
Wi-Fi Rating
AX11000
1.8 GHz
Line Properties
Line Coding Format
256 QAM, 1024 QAM, OFDMA
Internet of Things (IoT)
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 1 x 1G/2.5G Multi-Gig Ethernet - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 2 x 9 pin USB Type A
Aerial
Aerial
Internal
Antenna Qty
8
External power adapter
1 x network cable
Europe
OS Provided
No operating system
29.5 cm
22.7 cm
5.44 cm
1.1 kg
Limited warranty - 1 year , Limited warranty - technical support - 90 days
Standards: IEEE 802.11a
Standards: Ethernet
Standards: IEEE 802.11b
Standards: Gigabit Ethernet
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Standards: IEEE 802.11ax (Wi-Fi 6)
Standards: 2.5 Gigabit Ethernet
Standards: IEEE 802.11ac
Speed: 5.3Gbps
Brand: NETGEAR
