Got game? Well, this is the router for you! Built with gaming, streaming and mobile devices in mind, this Gigabit Wi-Fi router has a powerful processor and delivers extreme speed, so you enjoy less lag and less buffering. With Beamforming+ and built-in high-powered amplifiers and external antennas, get ready for the extreme!
Built for gaming, streaming and mobility
NETGEAR Nighthawk AC1900 Wi-Fi router was built to handle all your high-bandwidth online activities with features, that will keep you connected at top speeds. With the powerful processor and advanced upstream QoS for game consoles, Nighthawk can prioritize bandwidth to your game, so other devices on the network don't slow down your connection. Nighthawk also has downstream QoS and is optimized for streaming different applications, so you can enjoy uninterrupted video streaming with limited buffering. And with features, like high performance external antennas, and Beamforming+, you can enhance your mobile speeds so you can roam freely throughout your home without fear of slow or dropped connections. -
Simple and secure cloud storage
Access and share your files stored on a USB drive through NETGEAR ReadyCLOUD USB access. Simply plug your USB hard drive into your NETGEAR Nighthawk Wi-Fi router to create secure personal cloud storage. Enjoy the convenience and accessibility without the fees, storage limitations, or privacy concerns. Using the ReadyCLOUD, you'll now have anytime, anywhere access to your USB drive at home... it's that easy!
- NETGEAR Nighthawk AC1900 - wireless router - WWAN - Wi-Fi 5 - desktop
- Wireless router - wireless cellular modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Mobile Communication Protocol
- LTE
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 1900 Mbps
- Firewall protection, NAT support, VPN support, SPI, IPv6 support, parental control, QoS, WPS, ReadySHARE, Push ‘N’ Connect button, Circle Smart Parental Controls
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, DLNA CERTIFIED, IEEE 802.11ac
- 30.61 cm x 26.16 cm x 20.32 cm
- 1.125 kg
- Localisation
- Europe
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 1900 Mbps
- Encryption Algorithm
- WPA-PSK, WPA2-PSK
- Wi-Fi Rating
- AC1900
- Processor
- 1 GHz
- RAM
- 256 MB
- Flash Memory
- 128 MB
Communications
- Wireless cellular modem
- LTE
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A
- Expansion Slots
- 1 (total) / 1 (free) x Micro-SIM
Aerial
- Aerial
- External detachable
- Antenna Qty
- 3
- Power Device
- External power adapter
- Cables Included
- 1 x network cable - 1.5 m
- Localisation
- Europe
- Software Included
- NETGEAR Genie
- 30.61 cm
- 26.16 cm
- 20.32 cm
- 1.125 kg
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £13.89 |
