If you like gaming and streaming videos, then you'll benefit from Dynamic Quality of Service (QoS). Dynamic QoS resolves Internet traffic congestion when you have competing Internet demands at home. Dynamic QoS identifies your online activities by application and device, and then utilizes bandwidth allocation, and traffic prioritization techniques, to automatically allocate more bandwidth to latency sensitive applications like online gaming and video streaming, while ensuring that lower priority applications continue to work.
Access and share your files stored on a USB Drive through NETGEAR ReadyCLOUD USB Access. Simply plug your USB hard drive into your NETGEAR Nighthawk Wi-Fi Router to create secure personal cloud storage. Enjoy the convenience and accessibility of Google Drive and Dropbox without the fees, storage limitations, or privacy concerns. Using the ReadyCLOUD mobile app or web portal, you'll now have anytime, anywhere access to your USB drive at home, it's that easy!
Dynamic quality of service
If you like gaming and streaming videos, then you'll benefit from Dynamic Quality of Service (QoS). Dynamic QoS resolves Internet traffic congestion when you have competing Internet demands at home. Dynamic QoS identifies your online activities by application and device, and then utilises bandwidth allocation, and traffic prioritisation techniques, to automatically allocate more bandwidth to latency sensitive applications like online gaming and video streaming, while ensuring that lower priority applications continue to work. -
Simple and secure cloud storage
Access and share your files stored on a USB Drive through NETGEAR ReadyCLOUD USB Access. Simply plug your USB hard drive into your NETGEAR Nighthawk Wi-Fi Router to create secure personal cloud storage. Enjoy the convenience and accessibility of Google Drive and Dropbox without the fees, storage limitations, or privacy concerns. Using the ReadyCLOUD mobile app or web portal, you'll now have anytime, anywhere access to your USB drive at home, it's that easy! -
Safeguard your files with no worry backups
FREE ReadyShare Vault PC software it there for you to schedule automatic hassle-free backups to safeguard precious photos and files from any PC directly to the connected USB storage. ReadyShare Vault is FREE to download and use with your Nighthawk. -
Built for gaming, streaming and mobility
NETGEAR Nighthawk AC1900 Smart Wi-Fi Router was built to handle all your high-bandwidth online activities with features that will keep you connected at top speeds.
- NETGEAR Nighthawk AC1900 - network adapter - USB 3.0
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- SuperSpeed USB 3.0
- 11.9 cm x 4.6 cm x 2.2 cm
- 66.5 g
- Data Link Protocol
- Wi-Fi 5
- Data Transfer Rate
- 1300 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- System Requirements
- Apple MacOS X 10.8.3 or later, Microsoft Windows 7 / 8 / 10 (32/64 bits)
- Specific Absorption Rate (SAR)
- 1.43 W/kg
- Network adapter
- Form Factor
- External
- Connectivity Technology
- Wireless
- 1300 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- WPS, Push āNā Connect button, Beamforming+, dual band
Aerial
- Antenna
- Internal
- Antenna Qty
- 4
- Included Accessories
- Magnetic cradle
- Cables Included
- 1 x USB cable (external)
- 1.43 W/kg
- Software Included
- NETGEAR Genie
- OS Required
- 11.9 cm
- 4.6 cm
- 2.2 cm
- 66.5 g
- Technical support - 90 days
