The ProSAFE S3300 52PT Gigabit Stackable Smart Switch is a L2+ web based platform : PoE+ in a 48 port configuration. 4 dedicated 10G ports are included as standard (2 x 10GBase-T and 2 x SFP+) for stacking and/or uplinks to aggregation layers or storage and server connections. PoE/PoE+ support between 190W up to 1,440W with RPS (model dependent).
Robust security
With support for RADIUS and TACACS+ authentication methods, alongside a comprehensive Access Control List (ACL), the NETGEAR Smart S3300-52X-PoE+ ensures secure network access and precise control over user permissions. -
High capacity and performance
Designed to accommodate high traffic, this switch boasts a bandwidth of 176 Gbps, a MAC Address Table Size of 16K entries, and supports up to 256 VLANs, making it suitable for growing businesses. -
Efficient power management
Featuring PoE+ with a total budget of 390 W and ENERGY STAR Ethernet, the switch optimizes power usage, reducing operational costs while powering devices such as VoIP phones, IP cameras, and wireless access points. -
Advanced networking features
This switch supports a range of advanced features including Quality of Service (QoS) for traffic prioritization, IPv6 support, and static routing, enhancing network efficiency and preparing your infrastructure for the future. -
Reliable and manageable
With a mean time between failures (MTBF) of 216,809 hours, stackability up to 6 units, and comprehensive remote management protocols, the NETGEAR Smart S3300-52X-PoE+ is built for reliability and ease of management.
- NETGEAR Smart S3300-52X-PoE+ - switch - 52 ports - smart - rack-mountable
- Switch - 52 ports - smart - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 48 x 10/100/1000 (PoE+) + 2 x 10Gb Ethernet + 2 x 10Gb Ethernet SFP+
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 390 W
- Performance
- Bandwidth: 176 Gbps
- Capacity
- VLANs supported: 256 , ACL entries: 100 , IPv4 routes (static): 32 , DHCP snooping entries: 8000 , ARP entries: 512 , Forwarding table entries (Multicast): 512 , Priority queues per port: 8
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- 9KB
- Routing Protocol
- Static IPv4 routing
- Remote Management Protocol
- SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, HTTP, HTTPS, TFTP, CLI
- Flow control, trunking, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, ALG support, port mirroring, DiffServ support, WRR queuing, store and forward, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, WRED, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, MLD snooping, DAI, DHCP client, Energy Efficient Ethernet, dual firmware images, SPQ, CoS, IP source guard
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1as, IEEE 802.1ab (LLDP), IEEE 802.3an, IEEE 802.3az, IEEE 802.1Qat, IEEE 802.1Qav, IEEE 802.1BA
- Power
- AC 100/230 V (50/60 Hz)
- 44 cm x 34.5 cm x 4.3 cm
- 5.54 kg
- Localisation
- Latin America, North America, Europe
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 390 W
- Performance
- Capacity
- 16K entries
- 9KB
- Max Units In A Stack
- 6
- Routing Protocol
- Authentication Method
- RADIUS, TACACS+
- Processor
- : 800 MHz
- RAM
- 512 MB
- Flash Memory
- 128 MB
- 48 x 1000Base-T RJ-45 PoE+ , 2 x 10GBase-T RJ-45 uplink/stacking , 2 x 10Gbit LAN SFP+ uplink/stacking , 1 x USB 2.0 Type A
- Power Device
- Internal power supply
- Voltage Required
- 1484.12 Watt
- Redundant Power System (RPS) connector
- Rack Mounting Kit
- Included
- MTBF
- 216,809 hours
- CISPR 22 Class A, cUL, EN 60950, IEC950, UL 1950, EN55024, CSA 22.2 No. 950, EN55022 Class A, EN50082-1, CCC, RoHS, FCC Part 15 A, C-Tick Class A, VCCI Class A
- Localisation
- 44 cm
- 34.5 cm
- 4.3 cm
- 5.54 kg
- Limited warranty - replacement - lifetime - response time: next business day , Technical support - lifetime
- 0 °C
- 50 °C
- 0 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 0 - 95% (non-condensing)
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £13.93 |
