NetGear ProSafe Plus 5 Port Gigabit Ethernet Switch
LIFETIME WARRANTY
Quicklinx: 9J11WS00 Mfr#: GS105E-200UKS
Type: Gigabit Ethernet
Ports: 5
Data Transfer Rate: 1Gbps
Managed: No
POE: No
43 In Stock
£21.81 ex VAT
£26.17 inc VAT
Companies are putting more network traffic and applications on their Ethernet infrastructure. For example, the increasing deployments of VoIP phones and IP cameras require more than simple Plug-and-Play connectivity. It needs the network intelligence to separate the voice and video traffic from data, and prioritize them accordingly. Additionally, Internet-based applications such as Hotmail and Google Calendaring have made keeping the network up a business-critical need. However, companies do not necessarily have more money or advanced training to deal with complex managed switches. The NETGEAR ProSAFE Plus switch meets this growing need by providing fundamental network features that will help optimize the performance of business networks. ProSAFE Plus switch also offers traffic monitoring for users to observe traffic behavior. If there are connectivity issues, these switches can identify and even locate connection problems via cable diagnostic test. To optimize traffic through the switches, ProSAFE Plus switch offers both port and tag-based prioritization to keep latency-sensitive trai c moving ahead of less critical packets. Also, ProSAFE Plus switch offers port and 802.1Q-based VLAN as a means of improving security and network performance.
  • Robust connectivity
    Equipped with 5 RJ-45 connectors, this NETGEAR Plus GS105Ev2 switch supports 10/100/1000Base-T connections, ensuring versatile and high-speed connectivity options for a variety of network needs.
  • Enhanced network efficiency
    Features like Quality of Service (QoS), VLAN support, and Energy Efficient Ethernet make the GS105Ev2 a suitable solution for optimizing network traffic and reducing operational costs.
  • Advanced network security
    With capabilities such as DoS attack prevention, broadcast storm control, and loop prevention, the GS105Ev2 provides a secure networking environment, safeguarding your data from various threats.
  • High performance
    A 10 Gbps bandwidth capacity and support for jumbo frames up to 9KB ensure smooth and efficient handling of large data packets, making the GS105Ev2 suitable for demanding network environments.
  • Durable and reliable
    Designed for both durability and reliability, the GS105Ev2 operates within a wide range of temperatures and complies with multiple safety and environmental standards, including FCC, UL, and EN certifications.
NETGEAR Plus GS105Ev2 - switch - 5 ports - unmanaged
Switch - 5 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
Performance
Bandwidth: 10 Gbps
Virtual interfaces (VLANs): 64 , Layer 2 multicast groups: 128
MAC Address Table Size
8K entries
Jumbo Frame Support
9KB
Trunking, VLAN support, IGMP snooping, DoS attack prevention, port mirroring, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, Weighted Random Early Detection (WRED), Quality of Service (QoS), fanless, DHCP client, Energy Efficient Ethernet, Strict Priority Queuing (SPQ), loop prevention
IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3az
9.4 cm x 10.1 cm x 2.6 cm
0.27 kg
United Kingdom
NETGEAR lifetime warranty
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
Performance
Bandwidth: 10 Gbps
8K entries
Jumbo Frame Support
9KB
Status Indicators
Port transmission speed, power, link/activity
5 x 1000Base-T RJ-45
External power adapter
C-Tick, CISPR 22 Class B, UL 1950, EN50082-1, EN55022 Class B, FCC Part 15 B, EN55024 Class B, CCC Class B, VCCI Class B
United Kingdom
9.4 cm
10.1 cm
2.6 cm
0.27 kg
Limited warranty - lifetime , Limited warranty - power supply - 2 years
50 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
9J11 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
9J11 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.78
9J11 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £14.87
Ports: 5
Managed: No
POE: No
Brand: NETGEAR
