Companies are putting more network traffic and applications on their Ethernet infrastructure. For example, the increasing deployments of VoIP phones and IP cameras require more than simple Plug-and-Play connectivity. It needs the network intelligence to separate the voice and video traffic from data, and prioritize them accordingly. Additionally, Internet-based applications such as Hotmail and Google Calendaring have made keeping the network up a business-critical need. However, companies do not necessarily have more money or advanced training to deal with complex managed switches. The NETGEAR ProSAFE Plus switch meets this growing need by providing fundamental network features that will help optimize the performance of business networks. ProSAFE Plus switch also offers traffic monitoring for users to observe traffic behavior. If there are connectivity issues, these switches can identify and even locate connection problems via cable diagnostic test. To optimize traffic through the switches, ProSAFE Plus switch offers both port and tag-based prioritization to keep latency-sensitive trai c moving ahead of less critical packets. Also, ProSAFE Plus switch offers port and 802.1Q-based VLAN as a means of improving security and network performance.
Robust connectivity
Equipped with 5 RJ-45 connectors, this NETGEAR Plus GS105Ev2 switch supports 10/100/1000Base-T connections, ensuring versatile and high-speed connectivity options for a variety of network needs. -
Enhanced network efficiency
Features like Quality of Service (QoS), VLAN support, and Energy Efficient Ethernet make the GS105Ev2 a suitable solution for optimizing network traffic and reducing operational costs. -
Advanced network security
With capabilities such as DoS attack prevention, broadcast storm control, and loop prevention, the GS105Ev2 provides a secure networking environment, safeguarding your data from various threats. -
High performance
A 10 Gbps bandwidth capacity and support for jumbo frames up to 9KB ensure smooth and efficient handling of large data packets, making the GS105Ev2 suitable for demanding network environments. -
Durable and reliable
Designed for both durability and reliability, the GS105Ev2 operates within a wide range of temperatures and complies with multiple safety and environmental standards, including FCC, UL, and EN certifications.
- NETGEAR Plus GS105Ev2 - switch - 5 ports - unmanaged
- Switch - 5 ports - unmanaged
- Subtype
- Gigabit Ethernet
- Ports
- 5 x 10/100/1000
- Performance
- Bandwidth: 10 Gbps
- Capacity
- Virtual interfaces (VLANs): 64 , Layer 2 multicast groups: 128
- MAC Address Table Size
- 8K entries
- Jumbo Frame Support
- 9KB
- Trunking, VLAN support, IGMP snooping, DoS attack prevention, port mirroring, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, Weighted Random Early Detection (WRED), Quality of Service (QoS), fanless, DHCP client, Energy Efficient Ethernet, Strict Priority Queuing (SPQ), loop prevention
- IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3az
- 9.4 cm x 10.1 cm x 2.6 cm
- 0.27 kg
- Localisation
- United Kingdom
- NETGEAR lifetime warranty
- Enclosure Type
- Desktop
- Subtype
- Gigabit Ethernet
- Ports
- 5 x 10/100/1000
- Performance
- Capacity
- 8K entries
- 9KB
- Status Indicators
- Port transmission speed, power, link/activity
- 5 x 1000Base-T RJ-45
- Power Device
- External power adapter
- C-Tick, CISPR 22 Class B, UL 1950, EN50082-1, EN55022 Class B, FCC Part 15 B, EN55024 Class B, CCC Class B, VCCI Class B
- Localisation
- United Kingdom
- 9.4 cm
- 10.1 cm
- 2.6 cm
- 0.27 kg
- Limited warranty - lifetime , Limited warranty - power supply - 2 years
- 0 °C
- 50 °C
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £10.73 |
