NetGear ProSafe 8x10/100/1000 SM GB Switch PoE
LIFETIME WARRANTY
Quicklinx: 9RVQWS00 Mfr#: GS110TP-200EUS
Joining NETGEAR's ProSafe family of smart switch with high performance and cost efficiency, this 10-port Gigabit smart switch is packed with powerful features capable of enhancing any type of business network. The GS110TP is designed for customers who need a low port density solution with the combination of Gigabit speed and PoE capability. The GS110TP comes with 8 dedicated 10/100/1000 Mbps copper ports to connect to your end devices and two additional Gigabit fiber ports for uplinks with greater distance. With PoE capability on all 8 copper ports, the GS110TP can automatically detect PoE on the end devices and dynamically manage power assignments and priority. It is capable of delivering up to 15.4 W of power to devices such as wireless access points, IP phones and IP cameras, providing flexibility and ease of deployment to your network.
The GS110TP comes with a comprehensive set of features, such as enhanced VLAN and QoS, access control lists (ACL), 802.1x port authentication, rate limiting and IGMP snooping and many more, to provide businesses with networks that are geared for growth while ensuring performance and reliability.
With the fanless design and compact form factor, the GS110TP offers quiet operation and is suitable for deployments in any type of environment, especially the ones which are sensitive to noise.
  • PoE power management
    GS110TP offers useful PoE power management features to help you better control and monitor your power resource. The PoE timer can help turn off the PoE ports during certain times of the day so that your network can be more secure as well as energy efficient. It can also set prioritization on power usage so that specified ports are always guaranteed to get the power first if total power required exceeds the total power budget. The power will be assigned to the PoE ports dynamically depending on the reported power class from each of the individual network devices, allocating the required.
  • NETGEAR Green
    Up to 70% power savings compared to the non-Green version. Auto power-down mode saves energy when port is not in use.
  • Advanced Quality of Service (QoS)
    Priority queuing ensures high-priority traffic gets delivered efficiently, even during congestion from high-traffic bursts. Companies implementing network telephony or video conferencing, for example, need to be able to prioritize such voice and video traffic and other real-time applications over less latency-sensitive traffic to ensure reliability and quality. The ability to prioritize traffic ensures quality of latency-sensitive services and applications despite increasing traffic loads. The GS110TP provides an extensive set of QoS features: 802.1p-based prioritization, Layer 3-based prioritization, rate limiting.
  • Advanced security
    The GS110TP provides more robust security. This includes: 802.1x for authentication (MD5), ACL filtering to permit or deny traffic based on MAC or IP addresses.
  • Usability enhancements
    The GS110TP is a powerful switch, yet very easy to manage. It comes with many usability enhancements to help customers fully utilize the features for a more optimized and secure network. For example, the Auto Voice VLAN and Auto Video features will assist customers to easily set up VoIP or IP surveillance networks with a couple of simple steps. You don't need to be an IT professional to set up VoIP or IP surveillance. Security is critical for business networks. However, not everyone knows how to set up a secure network. The ACL Wizards on the GS110TP will guide even naïve users through the setup of access control and address filtering.
NETGEAR Smart GS110TP - v2 - switch - 8 ports - Managed
Switch - 8 ports - Managed
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE) + 2 x SFP
Power Over Ethernet (PoE)
PoE
PoE Budget
46 W
Performance
Bandwidth (full duplex): 20 Gbps
MAC Address Table Size
4K entries
Jumbo Frame Support
Routing Protocol
IGMPv2, IGMP
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS
VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, store and forward, Broadcast Storm Control, full duplex mode, Multicast Storm Control, Unicast Storm Control, SNTP support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Access Control List (ACL) support, Quality of Service (QoS), LLDP support, DHCP client, Management Information Base (MIB), 512KB packet buffer, Class of Service (CoS), 802.1x authentication, DiffServ Code Point (DSCP) support, administrator's password
IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP)
23.6 cm x 10.16 cm x 2.7 cm
700 g
Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
PoE
PoE Budget
46 W
Performance
4K entries
Jumbo Frame Support
Routing Protocol
IGMPv2, IGMP
Encryption Algorithm
MD5
Authentication Method
RADIUS, TACACS+
Status Indicators
Port transmission speed, power, PoE, link/activity
8 x 1000Base-T RJ-45 PoE , 2 x 1000Base-X SFP uplink
External power adapter
59.3 Watt
Rubber feet, wall mounting kit
MTBF
157,004 hours
FCC Class B certified, C-Tick, cUL, EN 60950, IEC950, EN55024, CB, VCCI Class B
Europe
Software Included
Drivers & Utilities
23.6 cm
10.16 cm
2.7 cm
700 g
90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
95% (non-condensing)
9RVQ C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
