The ProSAFE WC9500 High Capacity Wireless Controller is a scalable, high performance WLAN solution for centralized management of up to 200 ProSAFE wireless access points in a single wireless controller. Three WC9500 Wireless Controller can stack into a single cluster to support up to 600 Access Points, with a fourth WC9500 acting as a redundant backup. The supported AP’s extends from entry level single band WNAP210/WNAP320/WN370 APs to dual band business class WNDAP360/350, and premium grade 3x3 WNDAP660/620, and outdoor WND930 AP’s, and is also 802.11ac ready.
The WC9500 Wireless Controller is easy to configure with an intuitive user interface and setup wizard, comprehensive dashboard and monitoring statistics. Flexible enough to support a few dozen laptops to several thousand tablets, it delivers enterprise grade functionality for mid to large-sized organizations, but without the cost and complexity of big IT. The WC9500 comes fully equipped with enterprise grade features such as comprehensive wireless security (WPA, WPA2, Radius, LDAP, Rogue AP protection), guest access, and full networking functionality including embedded DHCP server, VLAN on wired and wireless networks support, to full Quality of Service differentiation. Additionally, with no recurring annual license fees: Simply pay as you grow.
Highly scalable 10 gigabit connectivity
Supports up to 200 Access Points and 12,000 concurrent clients per controller; stack up to three WC9500 controllers per wireless cluster; supporting up to 600 Access Points and 36,000 concurrent clients per cluster; consists of 2x10G connectivity with SFP+ form factor; backward compatible with 1G connectivity with SFP form factor; additional 1x1G port with RJ-45 copper connectivity. -
Enterprise-grade and feature-rich deployment solutions
Layer 2 and Layer 3 seamless roaming; dynamic RF adjustments; WLAN healing for automatic RF coverage in the case of AP failure; rogue AP detection; two redundant, hot-swap power supplies (PSU) (one PSU comes with the controller; second optional PSU is ordered separately); two removable fan trays provide front-to-back cooling airflow for best compatibility with data center hot aisle/cold aisle airflow patterns. -
Ultra-fast access point discovery with Ufast
Ufast AP discovery provides super-fast AP discovery; improves reliability and shortens setup time; secured communication between AP and WC9500. -
Distributed and local forwarding
Data traffic can be forwarded to the best path without traversing the controller; eliminates controller bottleneck for high throughput 802.11n APs; intelligent tunneling with Layer 2 and Layer 3 roaming. -
Investment protection
Supports ProSAFE access points; 802.11ac-ready for future deployments; hassle-free, plug-and-replace upgrade with ProSAFE WC7520 and WC7600.
 - NETGEAR High Capacity Wireless Controller WC9500 - network management device
 - Network management device
- Form Factor
 - External - 1U
- Localisation
 - Worldwide (excluding China)
- Data Link Protocol
 - Gigabit Ethernet, 10 Gigabit Ethernet
- Capacity
 - Manageable access points: 200 , Maximum number of access points (per cluster): 600 , BSSIDs: 144 , Concurrent stations per cluster: 36000 , Concurrent stations: 12000 , Profile groups: 9 , Profiles: 128 , Security profile groups per profile group: 9 , Detectable rogue access points: 512
- Power
 - AC 100/230 V
- Power Redundancy
 - 44 cm x 43 cm x 4.3 cm
 - 7.57 kg
 - NETGEAR lifetime warranty
- Designed For
 - NETGEAR Dual Band Wireless-N Access Point WNDAP350, Dual Band Wireless-N Access Point WNDAP360, Premium 3 x 3 Dual Band Wireless-N Access Point WNDAP660, WAC720, WAC730, WAC740 4 x 4, Wireless-N Access Point WNAP320, Wireless-N WNAP210 v2, WN370, WND930; Premium WAC740
- Height (Rack Units)
 - 1U
 - 44 cm
 - 43 cm
 - 4.3 cm
 - 7.57 kg
- Localisation
- Form Factor
 - External
- Connectivity Technology
 - Wired
 - TCP/IP, UDP/IP, ICMP/IP, IPSec, BOOTP, DHCP
- Routing Protocol
 - CIDR
- Remote Management Protocol
 - SNMP 1, RMON, Telnet, SNMP 2c, HTTP, TFTP, SSH
- Capacity
- Status Indicators
 - Power, status, fan
 - Auto-sensing per device, auto-negotiation, load balancing, LDAP support, VLAN support, Syslog support, stackable, IPv6 support, SNTP support, Wi-Fi Multimedia (WMM) support, Auto Channel Select (ACS), Access Control List (ACL) support, RADIUS support, roaming function, DHCP server, IPv4 support, rogue access point detection, tagged VLAN, Captive Portal
- Encryption Algorithm
 - DES, Triple DES, IKE, TKIP, WPA-PSK, AES-CCMP, AES-CCM, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise, AES-CBC, 128-bit SSL, 1024-bit RSA, 2048-bit RSA, TLS 1.1, WEP
- Authentication Method
 - X.509 certificates, Radio Service Set ID (SSID), TACACS, LDAP, Active Directory
 - IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e
 - 2 x 10Gb Ethernet - SFP+ , 1 x 1000Base-T (management) - RJ-45 , 1 x console - DB-9 , 1 x USB 2.0 - Type A
- MTBF
 - 664,072 hours
- Power Device
 - Internal power supply - hot-plug
- Installed Qty
 - 2
- Max Supported Qty
 - 2
- Power Redundancy
- Voltage Required
 - AC 100/230 V
 - 82.3 Watt
- Power Provided
 - 165 Watt
 - Limited warranty - replacement - lifetime - on-site - response time: next business day , Limited warranty - software application support - 90 days
 - 0 °C
 - 45 °C
 - 10 - 90%
- Designed For
 - NETGEAR Dual Band Wireless-N Access Point WNDAP350, Dual Band Wireless-N Access Point WNDAP360, Premium 3 x 3 Dual Band Wireless-N Access Point WNDAP660, WAC720, WAC730, WAC740 4 x 4, Wireless-N Access Point WNAP320, Wireless-N WNAP210 v2, WN370, WND930 , NETGEAR Premium WAC740
                        C2G 2m USB 2.0 A/B Cable - Black | In Stock | £3.63 |
