NetGear ProSAFE 500 WC9500 High Capacity Wireless Controller
LIFETIME WARRANTY
Quicklinx: B393WS00 Mfr#: WC9500-10000S
Type: Network management device
Connectivity: Wired
Speed: [N/A]
Protocol: 10 Gigabit Ethernet, Gigabit Ethernet
Compatibility: PC
£2,746.70 ex VAT
£3,296.04 inc VAT
The ProSAFE WC9500 High Capacity Wireless Controller is a scalable, high performance WLAN solution for centralized management of up to 200 ProSAFE wireless access points in a single wireless controller. Three WC9500 Wireless Controller can stack into a single cluster to support up to 600 Access Points, with a fourth WC9500 acting as a redundant backup. The supported AP’s extends from entry level single band WNAP210/WNAP320/WN370 APs to dual band business class WNDAP360/350, and premium grade 3x3 WNDAP660/620, and outdoor WND930 AP’s, and is also 802.11ac ready.
The WC9500 Wireless Controller is easy to configure with an intuitive user interface and setup wizard, comprehensive dashboard and monitoring statistics. Flexible enough to support a few dozen laptops to several thousand tablets, it delivers enterprise grade functionality for mid to large-sized organizations, but without the cost and complexity of big IT. The WC9500 comes fully equipped with enterprise grade features such as comprehensive wireless security (WPA, WPA2, Radius, LDAP, Rogue AP protection), guest access, and full networking functionality including embedded DHCP server, VLAN on wired and wireless networks support, to full Quality of Service differentiation. Additionally, with no recurring annual license fees: Simply pay as you grow.
  • Highly scalable 10 gigabit connectivity
    Supports up to 200 Access Points and 12,000 concurrent clients per controller; stack up to three WC9500 controllers per wireless cluster; supporting up to 600 Access Points and 36,000 concurrent clients per cluster; consists of 2x10G connectivity with SFP+ form factor; backward compatible with 1G connectivity with SFP form factor; additional 1x1G port with RJ-45 copper connectivity.
  • Enterprise-grade and feature-rich deployment solutions
    Layer 2 and Layer 3 seamless roaming; dynamic RF adjustments; WLAN healing for automatic RF coverage in the case of AP failure; rogue AP detection; two redundant, hot-swap power supplies (PSU) (one PSU comes with the controller; second optional PSU is ordered separately); two removable fan trays provide front-to-back cooling airflow for best compatibility with data center hot aisle/cold aisle airflow patterns.
  • Ultra-fast access point discovery with Ufast
    Ufast AP discovery provides super-fast AP discovery; improves reliability and shortens setup time; secured communication between AP and WC9500.
  • Distributed and local forwarding
    Data traffic can be forwarded to the best path without traversing the controller; eliminates controller bottleneck for high throughput 802.11n APs; intelligent tunneling with Layer 2 and Layer 3 roaming.
  • Investment protection
    Supports ProSAFE access points; 802.11ac-ready for future deployments; hassle-free, plug-and-replace upgrade with ProSAFE WC7520 and WC7600.
NETGEAR High Capacity Wireless Controller WC9500 - network management device
External - 1U
Worldwide (excluding China)
Gigabit Ethernet, 10 Gigabit Ethernet
Manageable access points: 200 , Maximum number of access points (per cluster): 600 , BSSIDs: 144 , Concurrent stations per cluster: 36000 , Concurrent stations: 12000 , Profile groups: 9 , Profiles: 128 , Security profile groups per profile group: 9 , Detectable rogue access points: 512
AC 100/230 V
Power Redundancy
44 cm x 43 cm x 4.3 cm
7.57 kg
NETGEAR lifetime warranty
NETGEAR Dual Band Wireless-N Access Point WNDAP350, Dual Band Wireless-N Access Point WNDAP360, Premium 3 x 3 Dual Band Wireless-N Access Point WNDAP660, WAC720, WAC730, WAC740 4 x 4, Wireless-N Access Point WNAP320, Wireless-N WNAP210 v2, WN370, WND930; Premium WAC740
Height (Rack Units)
1U
44 cm
43 cm
4.3 cm
7.57 kg
External
Wired
Network / Transport Protocol
TCP/IP, UDP/IP, ICMP/IP, IPSec, BOOTP, DHCP
Routing Protocol
CIDR
Remote Management Protocol
SNMP 1, RMON, Telnet, SNMP 2c, HTTP, TFTP, SSH
Status Indicators
Power, status, fan
Auto-sensing per device, auto-negotiation, load balancing, LDAP support, VLAN support, Syslog support, stackable, IPv6 support, SNTP support, Wi-Fi Multimedia (WMM) support, Auto Channel Select (ACS), Access Control List (ACL) support, RADIUS support, roaming function, DHCP server, IPv4 support, rogue access point detection, tagged VLAN, Captive Portal
Encryption Algorithm
DES, Triple DES, IKE, TKIP, WPA-PSK, AES-CCMP, AES-CCM, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise, AES-CBC, 128-bit SSL, 1024-bit RSA, 2048-bit RSA, TLS 1.1, WEP
Authentication Method
X.509 certificates, Radio Service Set ID (SSID), TACACS, LDAP, Active Directory
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e
2 x 10Gb Ethernet - SFP+ , 1 x 1000Base-T (management) - RJ-45 , 1 x console - DB-9 , 1 x USB 2.0 - Type A
MTBF
664,072 hours
Installed Qty
2
Max Supported Qty
2
Power Redundancy
AC 100/230 V
82.3 Watt
Power Provided
165 Watt
Limited warranty - replacement - lifetime - on-site - response time: next business day , Limited warranty - software application support - 90 days
45 °C
10 - 90%
NETGEAR Dual Band Wireless-N Access Point WNDAP350, Dual Band Wireless-N Access Point WNDAP360, Premium 3 x 3 Dual Band Wireless-N Access Point WNDAP660, WAC720, WAC730, WAC740 4 x 4, Wireless-N Access Point WNAP320, Wireless-N WNAP210 v2, WN370, WND930 , NETGEAR Premium WAC740
B393 C2G 2m USB 2.0 A/B Cable - Black In Stock £4.20
B393 C2G 5m USB 2.0 A/B Cable - Black In Stock £5.74
Connectivity: Wired
Speed: [N/A]
Protocol: Gigabit Ethernet
Compatibility: PC
Brand: NETGEAR
Price Range Ex VAT: £1500+
