NetGear ProSafe 48-Port Gigabit PoE Stackable Smart Switch 2nd Gen
LIFETIME WARRANTY
Quicklinx: 8410WS00 Mfr#: GS752TPSB-100EUS
Type: Gigabit Ethernet
Ports: 48
Data Transfer Rate: 1Gbps
Managed: Yes
POE: PoE
£942.63 ex VAT
£1,131.15 inc VAT
Enhanced Scalability and Network Convergence for Growing Businesses
The ProSAFE® Stackable Smart Switch series is unique in delivering the scalability, reliability, and performance growing small and medium-sized businesses need in an affordable and easy-to-manage package. The second generation of these Stackable Smart Switches consists of 4 models in 28/52-port configurations. Each switch in the series comes with a total of 6 SFP ports for fiber connectivity. Among them, 2 are shared, and the other 4 are dedicated for either stacking or uplinks. This new generation of Stackable Smart Switches offers two models that support PoE+ (up to 30W per port) allowing more flexible network deployments of PoE devices. The ProSAFE® Stackable Switch series offers the flexibility and scalability that will make it easier for growing businesses to seamlessly expand their network capacity.
Stacking for Scalability and High Availability
The new Generation of Stackable Smart Switches use 2 dedicated ports in the front of the switch for stacking, providing a 10Gbps, dual-ring, highly redundant stacking bus that carries intra-stack traffic and provide highest level of resilience, allowing you to stack up to six switches or up to 300 10/100/1000 Mbps ports, forming a virtual chassis for easy management under a single IP address. This stacking technology also provides several high-availability features to ensure business continuity:
Resiliency: Due to redundant stacking port connections, there is an automatic fail-over in case any switch in the stack fails, with rapid reconfiguration, thus preventing network downtime.
Hot-swappable: All switches in the stack are hot-swappable, and can be integrated or removed without disrupting the network.
Full-featured, Flexible 802.3at Power over Ethernet (PoE+)
With a total power budget of 192 Watts for the GS728TPS and 384 Watts for the GS752TPS, customers can choose to connect up to 48 802.3at IP-based devices in their network. Power-over-Ethernet (PoE) helps you optimize the installation and power management of network devices such as wireless access points (AP), VoIP phones, and IP-based surveillance cameras, and free your network deployment from restrictions of power outlet proximity using a standard Cat 5 cable. The first 8 ports on GS728TPS and GS752TPS also support 802.3at PoE+, providing up to 30 Watts of power for high-powered PoE devices such as videophones, RFID readers, access control systems. The switches are equipped with auto power budgeting functions, allowing flexibility in power management. The switches can prioritize how power is allocated, monitor power consumption and get alerts when power usage reaches a certain threshold.
Advanced Quality of Service (QoS)
Priority queuing ensures high-priority traffic gets delivered efficiently, even during congestion from high traffic bursts. Companies implementing network telephony or video conferencing, for example, need to be able to prioritize such voice and video traffic and other real-time applications over less latency-sensitive traffic to ensure reliability and quality. The ability to prioritize traffic ensures quality of latency-sensitive services and applications despite increasing traffic loads. Friendly to converged network with voice and video, the Stackable Smart Switches offers Auto Voice and Auto Video features that automatically configures QoS, Security and VLAN settings for IP phones and IP cameras.
Manageability and Support
There are various easy and convenient ways to manage the Stackable Smart Switch. The new Stackable Smart Switches can be managed by the Smart Control Center software which comes free with the switch. With it, you can discover and manage all NETGEAR Smart Switches from a central location, conduct mass configuration and firmware upgrade. If you have other NETGEAR business products in your network, you can also use the NMS200, NETGEAR's management platform for discovery and configuration of all your Netgear products in the network. For the peace of mind, these Stackable Smart Switches are backed by the NETGEAR ProSAFE® Lifetime Hardware Warranty and 1-year free 24x7 Advanced Technical Support*.
All Switches in the Stack are Hot-Swappable
These Stackable Smart Switches come with a complete suite of advanced features for more robust security, higher quality of service and high availability. This switch is equipped with highly advanced features such as access control lists (ACL), static routing, rate limiting, IGMP snooping, and Dynamic VLAN assignment among others to provide a small and medium sized business with a network that is geared for growth while providing scalability and reliability.
Advanced Security
These switches also provide advanced features that provide more robust security to SMBs.
IPv6 Support
IGMP filtering and querier ensure multicast streams are only delivered to interested receivers, preventing flooding even without a dedicated multicast router. When receivers are in different VLANs, Multicast VLAN registration (MVR) uses a dedicated multicast VLAN to forward multicast streams and avoid duplication for clients in different VLANs.
  • Stacking for scalability and high availability
    The stackable smart switch uses 2 dedicated dual-purpose ports in the front of the switch for stacking or uplink. The stacking function offers a 10 Gbps, dual-ring, highly redundant stacking bus that carries intra-stack traffic and provide the highest level of resilience, forming a virtual chassis for easy management under a single IP address.
  • Comprehensive and advanced feature sets
    This stackable smart switch comes with a complete suite of advanced features for more robust security, higher quality of service and high availability. This switch is equipped with highly advanced features such as access control lists (ACL), static routing, rate limiting, IGMP snooping, and dynamic VLAN assignment among others to provide a small and medium-sized business with a network that is geared for growth and network applications. Friendly to converged network with voice and video, the stackable smart switch offers auto voice and auto video features that automatically configure QoS, security and VLAN settings for IP phones and IP cameras.
  • IPv6 support
    In order to accommodate the move by Internet service providers to IPv6 addresses, the Gigabit stackable smart switch expand the IPv6 support beyond management only to QoS, ACL and multicast. It means that your network will benefit from the IPv6 enhancements and is future-proofed.
NETGEAR Smart GS752TPS - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 (PoE) + 2 x combo Gigabit SFP + 4 x Gigabit SFP
Power Over Ethernet (PoE)
PoE
Virtual interfaces (VLANs): 256
MAC Address Table Size
16K entries
Routing Protocol
IGMPv2, IGMP, IGMPv3, MLD
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP
Flow control, PoE, VLAN support, IGMP snooping, DoS attack prevention, port mirroring, Broadcast Storm Control, IPv6 support, full duplex mode, Multicast Storm Control, firmware upgradable, SNTP support, RSTP support, MSTP support, DHCP snooping, QoS, MLD snooping, PoE+, LLDP support, LACP, DHCP client, Energy Efficient Ethernet, static routing
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3at, IEEE 802.3az
AC 120/230 V (50 - 60 Hz)
44 cm x 31 cm x 4.3 cm
5.5 kg
Europe
NETGEAR lifetime warranty
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE
16K entries
Max Units In A Stack
6
Routing Protocol
RAM
128 MB DDR SDRAM
Flash Memory
32 MB
Status Indicators
Port transmission speed, power, PoE, link/activity, fan
48 x 1000Base-T RJ-45 PoE , 2 x 1000Base-T RJ-45 , 4 x SFP (mini-GBIC)
Internal power supply
526.8 Watt
Rack Mounting Kit
Included
C-Tick, EN 60950, EN55022, VCCI Class A ITE, EN55024, UL 60950, CB, CCC, FCC Part 15 A
Europe
44 cm
31 cm
4.3 cm
5.5 kg
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 95% (non-condensing)
8410 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £4.30
8410 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.73
8410 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.64
Ports: 48
Managed: Yes
POE: PoE
Brand: NETGEAR
Price Range Ex VAT: £750 - £1000
