NetGear PL1000 AV 1000 Powerline HomePlug Starter Kit
Quicklinx: BYL5WS00 Mfr#: PL1000-100UKS
Type: Powerline adapter kit
Speed: 1Gbps
Connectivity: Wired
Pass-through Socket: No
£50.27 ex VAT
£60.32 inc VAT
Netgear Powerline 1000 (PL1000)
Extend your wired Internet access to any room in your house using your existing electrical wiring. Just plug the Powerline 1000 into any electrical outlet then plug in your device into the adapter. It's that easy. With its high speed and Homeplug AV2 support, the Powerline 1000 adapter is perfect for connecting smart TVs, streaming players, and game consoles.
Whats in the box?
  • NETGEAR Powerline PL1000
  • 2 x network cable - 2m
Key Features
  • Powerful speed
  • Perfect for connecting smart TVs, streaming players and game consoles
  • Ideal for HD streaming and lag-free gaming
  • Pick-a-plug LED for high performance
  • Sets up in minutes, no need to install software
  • Secures the network connection with the touch of a button
  • Energy saving - powers down when not connected
Product Features
  • Get connected with Powerline - NETGEAR Powerline is an easy way to extend a wired Internet connection to any room without running long wires. Just plug into any electrical outlet and connect your device to the Ethernet port. It's that easy.
  • Reliable networking - Connect multiple adapters to expand your wired network reliably.
  • Advanced technology - Homeplug AV2 support for Gigabit speeds through your electrical outlets for improved coverage.
  • Plug-and-play - Setup in minutes, no need to configure or install software.
  • Energy-saving - Automatically powers down when not in use.
  • Push-and-secure - Encrypts Powerline network connections with the touch of a button.
NETGEAR Powerline PL1000 - powerline adapter kit - wall-pluggable
Packaged Quantity
2 (specifications are for single item)
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV) 2.0
Data Transfer Rate
1 Gbps
IEEE 802.3, HomePlug AV 2.0, IEEE 1901
AC 120/230 V
5.9 cm x 3.59 cm x 10 cm
126 g
Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8
United Kingdom
1-year warranty
Packaged Quantity
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
1 Gbps
1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x HomePlug AV 2.0
Internal power supply
AC 120/230 V
5 Watt
2 x network cable - 2 m
United Kingdom
5.9 cm
3.59 cm
10 cm
126 g
Limited warranty - 1 year , Technical support - 90 days
Speed: 1Gbps
Connectivity: Wired
Brand: NETGEAR
