The NETGEAR 200 series unmanaged switch provides easy and affordable network connectivity to home and small offices. It is easy to use and reliable. With these Plug-and-Play switch, you can expand your network connections to multiple devices instantly. The 200 series also supports the efficient use of energy, helping you save power and money.
Efficient connectivity
The NETGEAR GS205 switch offers seamless connectivity with its five 10/100/1000 ports, ensuring high-speed network access for multiple devices. Its auto-uplink (auto MDI/MDI-X) feature automatically adjusts for straight-through or crossover cables, simplifying setup and maintenance. -
Reliable performance
Designed for efficiency, the switch features a store and forward mechanism to minimize packet loss, and a robust 4K entry MAC address table that accommodates a large number of network devices. This combination ensures a smooth and reliable network experience. -
Easy monitoring
With status indicators for link/activity and power, monitoring the network's status is straightforward. These indicators provide real-time feedback, making it easier to diagnose and resolve any issues promptly.
- NETGEAR GS205 - switch - 5 ports - unmanaged
- Switch - 5 ports - unmanaged
- Subtype
- Gigabit Ethernet
- Ports
- 5 x 10/100/1000
- Performance
- Bandwidth: 10 Gbps
- MAC Address Table Size
- 4K entries
- Auto-uplink (auto MDI/MDI-X), store and forward
- IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab
- 11.4 cm x 8.6 cm x 2.6 cm
- 122 g
- Localisation
- United Kingdom
- Enclosure Type
- Desktop
- Subtype
- Gigabit Ethernet
- Ports
- 5 x 10/100/1000
- Performance
- 4K entries
- Status Indicators
- Power, link/activity
- 5 x 1000Base-T RJ-45
- Power Device
- External power adapter
- 3.56 Watt
- Localisation
- United Kingdom
- 11.4 cm
- 8.6 cm
- 2.6 cm
- 122 g
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.73 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £12.76 |
