NetGear AC1200 WiFi Range Extender
Quicklinx: BYL3WS00 Mfr#: EX6120-100UKS
Type: Wi-Fi range extender
Speed: 1200Mbps
Connectivity: Wireless
Pass-through Socket: No
  • IEEE 802.11n
42 In Stock
£40.44 ex VAT
£48.52 inc VAT
The AC1200 WiFi Range Extender Essentials Edition boosts WiFi range for speeds up to 1200 Mbps, suitable for HD video streaming and gaming. It works with any standard WiFi router and is suitable for iPads, smartphones, laptops and more. Its convenient size makes it one of the world’s smallest AC1200 wall-plug extenders.
  • Extend dual band Wi-Fi up to 1200 Mbps and reduce interference.
  • External antennas for better Wi-Fi coverage and more speed.
  • Gigabit Ethernet port - connect a wired device like Blu-ray player, game console or smart TV to your Wi-Fi network.
  • Two Wi-Fi modes - extend existing Wi-Fi connection or create a AC Wi-Fi access point.
  • FastLane technology - use both Wi-FI bands to establish one very high-speed connection; suitable for HD streaming and gaming.
Enjoy Life in The Fast Lane
With FastLane technology, use both Wi-Fi bands to establish one super speed connection; suitable for HD streaming and gaming.
Connectivity you Can't be Without
With one Gigabit ports that act as a Wi-Fi bridge, the AC1200 Wi-Fi range extender is also suitable for connecting devices like gaming consoles, smart TVs and streaming players to your Wi-Fi network, upgrading all of your entertainment devices to 11AC speed in a single shot.
Mobile Up to 100 Per Cent Faster
Improve your mobile Wi-Fi speeds by up to 100 per cent with AC1200 Wi-Fi range extender. External antennas help extend Wi-Fi coverage throughout large homes and even backyards. Experience what it means to be mobile.
In a Deadzone? Not Anymore
Is there a void space between your Wi-Fi router and your devices? Add a Wi-Fi range extender and strengthen your connection while improving connectivity.
Wi-Fi Analytics App
Use the NETGEAR Wi-Fi analytics app and get enhanced analytics to optimise your existing or newly extended Wi-Fi network. Check your network status, Wi-Fi signal strength, identify crowded Wi-Fi channels and much more. Here’s what you can do with the Wi-Fi Analytics App.
  • Get a network status overview.
  • Check Wi-Fi signal strength.
  • Measure Wi-Fi channel interference.
  • Keep track of Wi-Fi strength by location.
  • More Wi-Fi standards
    Create faster access for 802.11 b/g/n & AC Wi-Fi devices.
  • Two Wi-Fi modes
    Extend existing Wi-Fi connexion or create a AC Wi-FI access point.
  • Gigabit Ethernet Port
    Connect a wired device like Blu-ray player, game console, smart TV or streaming player to your Wi-Fi network.
  • Simultaneous dual band Wi-Fi
    Extend 2.4 & 5GHz Wi-Fi up to 1200Mbps & reduce interference.
  • External antennas
    For better Wi-Fi coverage.
    Use both Wi-Fi bands to establish one super high-speed connexion; ideal for HD streaming & gaming.
NETGEAR EX6120 - Wi-Fi range extender - Wi-Fi 5
External
United Kingdom
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
5.517 cm x 3.9 cm x 6.717 cm
130 g
5.517 cm
3.9 cm
6.717 cm
130 g
United Kingdom
External
Wireless
Data Transfer Rate
1200 Mbps
Frequency Band
2.4 GHz, 5 GHz
Auto-sensing per device, Wi-Fi Protected Setup (WPS), Push ‘N’ Connect button
Encryption Algorithm
WPA-PSK, WPA2-PSK, WEP
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac
Aerial
Antenna
External integrated
Antenna Qty
2
1 x 100Base-TX - RJ-45
Internal power supply
Speed: 1200Mbps
Brand: NETGEAR
