The NETGEAR SOHO Ethernet switches provide easy and affordable network connectivity to small offices and home/offices. They are easy to use, reliable, and rugged with metal enclosures. With these Plug-n-play switches, you can quickly and easily expand your network connections to multiple devices, with no configuration required. These switches also support various energy saving technologies, helping you save power and money.
- NETGEAR SOHO Gigabit Ethernet Switch GS308P - switch - 8 ports - unmanaged
- Switch - 8 ports - unmanaged
- Subtype
- Gigabit Ethernet
- Ports
- 4 x 10/100/1000 (PoE) + 4 x 10/100/1000
- Power Over Ethernet (PoE)
- PoE
- PoE Budget
- 53 W
- Performance
- Bandwidth: 16 Gbps
- MAC Address Table Size
- 4K entries
- Jumbo Frame Support
- 9720 bytes
- Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), Quality of Service (QoS), Green Ethernet, fanless, Energy Efficient Ethernet, security lock slot (cable lock sold separately), 1.5MB packet buffer
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3az
- 15.8 cm x 10.1 cm x 2.9 cm
- 460 g
- Localisation
- United Kingdom
- 3-year warranty
- Enclosure Type
- Desktop, wall-mountable
- Subtype
- Gigabit Ethernet
- Ports
- PoE
- PoE Budget
- 53 W
- Performance
- 4K entries
- 9720 bytes
- Status Indicators
- Power, PoE, link/activity
- 4 x 1000Base-T RJ-45 PoE - 15.4 W , 4 x 1000Base-T RJ-45
- Power Device
- External power adapter
- 60 Watt
- MTBF
- 2,244,211 hours
- CB, CCC, FCC Part 15 A
- Localisation
- United Kingdom
- 15.8 cm
- 10.1 cm
- 2.9 cm
- 460 g
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 95%
