NetGear M6100 Series 48 x 1G Blade
Quicklinx: B38ZWS00 Mfr#: XCM8948-10000S
The new ProSAFE M6100 Chassis series is set to shake up how SMBs deploy high performance, highly resilient, fully redundant and future proof switched networks from the Core to the Edge - without hurting or exhausting IT budgets. The NETGEAR LAN Access and Aggregation Chassis M6100 series delivers L2/L3/L4 and IPv4/IPv6 rich services for enterprise edge and SMB core deployments, as well as 1G / 10G mixed infrastructures in server rooms. Innovative distributed fabric provides non-stop forwarding resiliency and world-class availability - including passive backplane, hitless failover, redundant fabric and redundant management - without having to pay the exorbitant acquisition and maintenance costs associated by other networking vendors in this class.
Designed for use at the center of a small to mid-sized organization, or as an aggregate or access solution in a larger campus or mid-sized enterprise branch network, the application scenarios for the M6100 are both wide and diverse.
No single point of failure with management and power backup and distributed link aggregation across multiple chassis arrangements.
No performance compromise. With up to 10 x performance of fixed stackable solutions with similar port counts, value performance ratios are unrivaled.
Decide on the port count and speeds you need, from 144 Gigabit ports through to 72 10 Gigabit ports, or a combination of both.
  • Chassis Standards Redefined
  • All in one solution
  • Distributed fabric, passive backplane
    NO single point of failure with management and power backup and distributed link aggregation across multiple chassis arrangements.
  • 480Gbps inter-module backplane performance
  • Gigabit and 10G blades offering deployment flexibility for today and tomorrow's needs
NETGEAR XCM8948 - switch - 48 ports - plug-in module
Switch - 48 ports
Enclosure Type
Plug-in module
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000
24 MB packet buffer
48.26 cm x 32.35 cm x 4.05 cm
3.23 kg
NETGEAR lifetime warranty
Switch - 48 ports
Enclosure Type
Plug-in module
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000
24 MB packet buffer
RAM
1 GB
Flash Memory
64 MB
Status Indicators
Port transmission speed, status, link/activity, supervisor
48 x 1000Base-T RJ-45 , 1 x management (Gigabit LAN) RJ-45 , 1 x serial RJ-45 , 1 x management (mini-USB) , 1 x USB Type A
60 Watt
2 x console cable
MTBF
862,954 hours
48.26 cm
32.35 cm
4.05 cm
3.23 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - phone consulting - 90 days , Technical support - e-mail consulting - 90 days , Technical support - web support - lifetime
B38Z C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
