Enhanced cooling efficiency
The fan tray's front to back design ensures optimal airflow, significantly improving the cooling efficiency of your PC setup. By maintaining lower temperatures, it enhances the overall performance and longevity of your components. -
Seamless compatibility
Designed specifically with PC compatibility in mind, this fan tray integrates smoothly into your system, ensuring a hassle-free setup and operation. Its precise engineering ensures a perfect fit with your existing hardware, making it an essential addition to your cooling solutions.
 - NETGEAR fan tray (front to back)
- Product Type
 - Fan tray (front to back)
 - 40.3 cm x 8.5 cm x 12.56 cm
 - 1.78 kg
 - 5-year warranty
- Designed For
 - NETGEAR M6100-44G3-POE+
- Product Type
 - 40.3 cm
 - 8.5 cm
 - 12.56 cm
 - 1.78 kg
 - Limited warranty - 5 years
- Designed For
