The ProSAFE M6100 Switch Series consists of Gigabit access layer and 10 Gigabit distribution layer switches in NETGEAR modular chassis switch product line. The M6100 switch series offers high-quality, high-density chassis alternative to stackable switches in campus LAN and midsize organizations demanding networks. With more than 1.4 Tbps switching and routing capacity, passive backplane, management and fabric nonstop forwarding redundancy, the M6100 series delivers world-class resiliency and scalability. Ultimately, operating software and system management features take the complexity out of delivering L2/L3/L4 rich services for enterprise edge and SMB core deployments.
Robust security
With support for RADIUS, Secure Shell (SSH), SSH2, and TACACS+, the NETGEAR M6100-44G3-POE+ ensures secure network access and management, safeguarding your data from unauthorized access. -
High capacity networking
Designed to meet the demands of high-volume networking, this switch supports up to 4000 VLANs, 512 static routes, and both IPv4 and IPv6 forwarding, making it an ideal choice for complex network environments. -
Efficient power management
Featuring PoE+ with a power budget of 30 W per port across 40 ports, the NETGEAR M6100-44G3-POE+ delivers efficient power management, reducing operational costs and simplifying the deployment of PoE devices. -
Advanced networking features
This switch comes equipped with a plethora of advanced features including Quality of Service (QoS), access control lists (ACL), and support for multiple routing protocols, enhancing network performance and reliability. -
Flexible connectivity options
With 44 Gigabit Ethernet ports, 2 10Gb Ethernet ports, and 2 10 Gigabit SFP+ ports, the NETGEAR M6100-44G3-POE+ offers a wide range of connectivity options for diverse networking requirements.
- NETGEAR M6100-44G3-POE+ - Starter Kit - switch - 44 ports - Managed - rack-mountable
- Switch - 44 ports - L4 - Managed
- Enclosure Type
- Rack-mountable 4U
- Subtype
- Gigabit Ethernet
- Ports
- 40 x 10/100/1000 + 2 x 10Gb Ethernet + 2 x 10 Gigabit SFP+
- Power Over Ethernet (PoE)
- PoE+
- Capacity
- Virtual interfaces (VLANs): 4000 , Static routes: 512 , RIP routes: 512 , OSPF routes: 12000 , BGP routes: 12000 , ARP entries: 8000 , IPv4 forwarding table entries: 1536 , IPv6 forwarding table entries: 512
- MAC Address Table Size
- 32000 entries
- Jumbo Frame Support
- 12KB
- Routing Protocol
- OSPF, BGP-4, RIP-1, RIP-2, BGP, IGMPv2, DVMRP, VRRP, OSPFv2, PIM-SM, PIM-DM, IGMPv3, OSPF for IPv6, OSPFv3, static IPv4 routing, static IPv6 routing, ECMP, policy-based routing (PBR), MLDv2, PIM-SMv6, BGP for IPv6, PIM-DMv6
- Remote Management Protocol
- SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, HTTP, HTTPS, SSH, CLI
- BOOTP support, ARP support, trunking, VLAN support, IGMP snooping, Syslog support, traffic shaping, DoS attack prevention, port mirroring, DiffServ support, WRR queuing, store and forward, MAC address filtering, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, WFQ, WRED, sFlow, STP support, RSTP support, PVST, MSTP support, DCBX support, priority-based flow control, DHCP snooping, TFTP support, ACL support, QoS, DHCP server, MLD snooping, DAI, STP Root Guard, UDLD, DWRR, LLDP support, DHCP relay, RSPAN, PVRST, DHCP client, Energy Efficient Ethernet, MIB, dual firmware images, MVRP, SPQ, CoS, tagged VLAN, GARP, IGMP proxy, ToS, DSCP support, MLD proxy, FIP
- IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.3ac, IEEE 802.1s, IEEE 802.1v, IEEE 802.1as, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az, IEEE 802.1AX, IEEE 802.1Qbb, IEEE 802.1Qaz
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- 43.2 cm x 44.16 cm x 17.59 cm
- NETGEAR lifetime warranty
- Enclosure Type
- Rack-mountable 4U
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- Capacity
- 32000 entries
- 12KB
- Routing Protocol
- Encryption Algorithm
- AES, TLS 1.0, SSL 3.0
- Authentication Method
- Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
- Processor
- 1: 800 MHz
- RAM
- 1 GB
- Flash Memory
- 64 MB
- Status Indicators
- Port transmission speed, power, status, link/activity, supervisor
- 40 x 1000Base-T RJ-45 PoE+ - 30 W , 2 x 10GBase-T RJ-45 , 2 x 10GBase-X SFP+ , 1 x management (Gigabit LAN) RJ-45 , 1 x serial RJ-45 , 1 x management (mini-USB) , 1 x USB Type A
- Expansion Slots
- 3 (total) / 2 (free) x Expansion Slot
- Installed Modules Qty (Max)
- 1 (installed) / 3 (max)
- Power Device
- Internal power supply - hot-plug
- Installed Qty
- 1
- Max Supported Qty
- 4
- Power Redundancy
- Optional
- Power Redundancy Scheme
- N+1
- Power Provided
- 1000 Watt
- Voltage Required
- 80 PLUS Certification
- 80 PLUS
- Redundant Power System (RPS) connector
- Included Accessories
- Fan tray
- Rack Mounting Kit
- Included
- CISPR 22 Class A, cUL, EN 60950, IEC950, UL 1950, EN55024, CSA 22.2 No. 950, EN55022 Class A, EN50082-1, FCC Part 15 A, C-Tick Class A, VCCI Class A
- 43.2 cm
- 44.16 cm
- 17.59 cm
- Limited warranty - replacement - lifetime - response time: next business day , Technical support - phone consulting - 90 days , Technical support - e-mail consulting - 90 days , Technical support - web support - lifetime
- 0 °C
- 50 °C
- 0 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 0 - 95% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.73 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £12.76 |
