NETGEAR M4300-52G-POE+ Managed Switch APS1000W
Quicklinx: C4YXWS00 Mfr#: GSM4352PB-100NES
Type: 10 Gigabit Ethernet
Ports: 52
Data Transfer Rate: [N/A]
Managed: Yes
POE: PoE+
Hurry, only 1 left in stock!
£2,774.12 ex VAT
£3,328.94 inc VAT
The NETGEAR M4300 Switch Series delivers L2/L3/L4 and IPv4/IPv6 rich services for enterprise edge and SMB aggregation deployments with unrivaled ease of use: 10 Gigabit models can seamlessly stack with 1 Gigabit models within the series. Non-stop forwarding virtual chassis architecture provides advanced High Availability (HA) with hitless failover, that is, distributed link aggregation allows for load balancing and virtually zero downtime. License-free L3 feature set includes static routing, policy-based routing, RIP, VRRP, OSpiv as well as Multicast PIM routing. The NETGEAR M4300 Switch Series is ready for the future, with Software-defined Network (SDN) and OpenFlow 1.3 enabled for your network.
M4300-52G-PoE+ comes with 48 ports 1G PoE+ capable of full provisioning, 2 ports 10GBASE-T and 2 ports 10GBASE-X SFP+ in a full-width form factor. All 4 ports 10G are independent and can be used for stacking or uplinks: they are 1G backward compatible. In this GSM4352PB version, M4300-52G-PoE+ is delivering resilient and secure access layer in campus LAN environments and commercial buildings. Ideal for wireless access, unified communications and IP video applications: 591W (110V AC) or 860W (220V AC) PoE budget is provided by one APS1000W PSU. A second one will add 1+1 power redundancy in RPS mode, and extended 1,010W (110V AC) or 1,440W (220V AC) PoE budget in EPS shared mode. An additional RPS port is available for redundant power protection using external RPS, when both internal PSUs are used in EPS shared mode.
  • Outstanding stacking
    M4300 is flexible enough for mixed stacking between 10 Gigabit and 1 Gigabit models, using any 10G port with any media type (RJ45, SFP+, DAC cables) High-availability is another key differentiator for stackable solutions: in case of a master switch failure, NSF and hitless failover ensure the standby switch takes over while forwarding plane continues to forward traffic on the operational stack members without any service interruption.
  • Higher flexibility
    Two half-width M4300 switches can be paired in a single rack space for redundant Top of Rack installations with Auto-iSCSI prioritization. 10 Gigabit ports are all independent and 1G backward compatible for progressive transition to 10G speeds.
  • Investment protection
    Line-rate spine and leaf stacking topologies offer multiple possibilities in server rooms, in branch collapsed cores or at the edge of growing networks. Even if an organization is not ready for SDN, OpenFlow support offers future-ready design for maximum investment protection.
  • Secure services
    With successive tiering, the Authentication Manager allows for authentication methods per port for a tiered authentication based on configured time-outs.
  • Industry standard management
    Industry standard command line interface (CLI), functional NETGEAR web interface (GUI), SNMP, sFlow and RSPAN. Single-pane-of-glass NMS300 management platform with centralized firmware updates and mass-configuration support.
NETGEAR M4300-52G-PoE+ - switch - 52 ports - Managed - rack-mountable
Switch - 52 ports - L3 - Managed - stackable
Enclosure Type
Front to back airflow rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
2 x 10/100/1000/10000 + 2 x 10 Gigabit SFP+ + 48 x 10/100/1000 (PoE+)
Power Over Ethernet (PoE)
PoE+
PoE Budget
860 W
Performance
Switching capacity: 176 Gbps
Routing Protocol
OSPF, RIP, IGMPv2, IGMP, VRRP, PIM-SM, PIM-DM, IGMPv3, MLDv2
Remote Management Protocol
SNMP, Telnet, HTTPS, SSH, CLI
ARP support, DiffServ support, IPv6 support, STP support, RSTP support, VRRP support, DHCP snooping, ACL support, QoS, MLD snooping, STP Root Guard, IPv4 support, LACP support, DHCP relay, RSPAN, PVRST, dynamic ARP protection, IP source guard, BPDU, LISP ASM, SSM
IEEE 802.3ad (LACP), IEEE 802.3az
AC 120/230 V
Europe, Americas
NETGEAR lifetime warranty
Enclosure Type
Subtype
10 Gigabit Ethernet
Ports
PoE+
PoE Budget
860 W
Performance
Max Units In A Stack
8
Routing Protocol
Authentication Method
RADIUS, TACACS+
2 x 10GBase-T RJ-45 , 2 x 10GBase-X SFP+ , 1 x management (Gigabit LAN) RJ-45 , 1 x serial (RS-232) RJ-45 , 1 x console (mini-USB) , 1 x USB Type A , 48 x 1000Base-T RJ-45 PoE+
Internal power supply
Installed Qty
1
Max Supported Qty
2
Power Provided
1000 watt
AC 120/230 V
Europe, Americas
Limited warranty - lifetime
C4YX C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.67
C4YX C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.82
C4YX NetGear 1000W Power Brick for RPS4000 In Stock £624.94
Ports: 52
Managed: Yes
POE: PoE+
Brand: NETGEAR
Price Range Ex VAT: £1500+
