The NETGEAR M4300 Switch Series delivers L2/L3/L4 and IPv4/IPv6 rich services for enterprise edge and SMB aggregation deployments with unrivaled ease of use: 10 Gigabit models can seamlessly stack with 1 Gigabit models within the series. Non-stop forwarding virtual chassis architecture provides advanced High Availability (HA) with hitless failover, that is, distributed link aggregation allows for load balancing and virtually zero downtime. License-free L3 feature set includes static routing, policy-based routing, RIP, VRRP, OSpiv as well as Multicast PIM routing. The NETGEAR M4300 Switch Series is ready for the future, with Software-defined Network (SDN) and OpenFlow 1.3 enabled for your network.
M4300-52G comes with 48 ports 1G, 2 ports 10GBASE-T and 2 ports 10GBASE-X SFP+ in a full-width form factor. All 4 ports 10G are independent and can be used for stacking or uplinks: they are 1G backward compatible. M4300-52G is delivering resilient and secure access layer in campus LAN environments and commercial buildings. Ideal for server and storage applications: 1+1 PSU protection and front to back cooling ensure hot and cold aisle compliance.
- NETGEAR M4300-52G - switch - 52 ports - Managed - rack-mountable
- Switch - 52 ports - L3 - Managed - stackable
- Enclosure Type
- Front to back airflow rack-mountable 1U
- Subtype
- 10 Gigabit Ethernet
- Ports
- 2 x 10/100/1000/10000 + 2 x 10 Gigabit SFP+ + 48 x 10/100/1000
- Performance
- Switching capacity: 176 Gbps
- Routing Protocol
- OSPF, RIP, IGMPv2, IGMP, VRRP, PIM-SM, PIM-DM, IGMPv3, MLDv2
- Remote Management Protocol
- SNMP, Telnet, HTTPS, SSH, CLI
- ARP support, DiffServ support, IPv6 support, STP support, RSTP support, VRRP support, DHCP snooping, ACL support, QoS, MLD snooping, STP Root Guard, IPv4 support, LACP support, DHCP relay, RSPAN, PVRST, dynamic ARP protection, IP source guard, BPDU, LISP ASM, SSM
- IEEE 802.3ad (LACP), IEEE 802.3az
- Power
- AC 120/230 V
- Localisation
- Europe, Americas
- NETGEAR lifetime warranty
- Enclosure Type
- Subtype
- Ports
- Performance
- Max Units In A Stack
- 8
- Routing Protocol
- Authentication Method
- RADIUS, TACACS+
- 2 x 10GBase-T RJ-45 , 2 x 10GBase-X SFP+ , 1 x management (Gigabit LAN) RJ-45 , 1 x serial (RS-232) RJ-45 , 1 x console (mini-USB) , 1 x USB Type A , 48 x 1000Base-T RJ-45
- Power Device
- Internal power supply
- Installed Qty
- 1
- Max Supported Qty
- 2
- Power Provided
- 150 Watt
- Voltage Required
- AC 120/230 V
- Localisation
- Europe, Americas
- Limited warranty - lifetime
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £4.30 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.73 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £12.64 |
