NETGEAR M4300-52G Managed Switch
Quicklinx: C4YZWS00 Mfr#: GSM4352S-100NES
Type: 10 Gigabit Ethernet
Ports: 52
Data Transfer Rate: [N/A]
Managed: Yes
POE: No
£1,747.67 ex VAT
£2,097.20 inc VAT
The NETGEAR M4300 Switch Series delivers L2/L3/L4 and IPv4/IPv6 rich services for enterprise edge and SMB aggregation deployments with unrivaled ease of use: 10 Gigabit models can seamlessly stack with 1 Gigabit models within the series. Non-stop forwarding virtual chassis architecture provides advanced High Availability (HA) with hitless failover, that is, distributed link aggregation allows for load balancing and virtually zero downtime. License-free L3 feature set includes static routing, policy-based routing, RIP, VRRP, OSpiv as well as Multicast PIM routing. The NETGEAR M4300 Switch Series is ready for the future, with Software-defined Network (SDN) and OpenFlow 1.3 enabled for your network.
M4300-52G comes with 48 ports 1G, 2 ports 10GBASE-T and 2 ports 10GBASE-X SFP+ in a full-width form factor. All 4 ports 10G are independent and can be used for stacking or uplinks: they are 1G backward compatible. M4300-52G is delivering resilient and secure access layer in campus LAN environments and commercial buildings. Ideal for server and storage applications: 1+1 PSU protection and front to back cooling ensure hot and cold aisle compliance.
NETGEAR M4300-52G - switch - 52 ports - Managed - rack-mountable
Switch - 52 ports - L3 - Managed - stackable
Enclosure Type
Front to back airflow rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
2 x 10/100/1000/10000 + 2 x 10 Gigabit SFP+ + 48 x 10/100/1000
Performance
Switching capacity: 176 Gbps
Routing Protocol
OSPF, RIP, IGMPv2, IGMP, VRRP, PIM-SM, PIM-DM, IGMPv3, MLDv2
Remote Management Protocol
SNMP, Telnet, HTTPS, SSH, CLI
ARP support, DiffServ support, IPv6 support, STP support, RSTP support, VRRP support, DHCP snooping, ACL support, QoS, MLD snooping, STP Root Guard, IPv4 support, LACP support, DHCP relay, RSPAN, PVRST, dynamic ARP protection, IP source guard, BPDU, LISP ASM, SSM
IEEE 802.3ad (LACP), IEEE 802.3az
AC 120/230 V
Europe, Americas
NETGEAR lifetime warranty
Enclosure Type
Subtype
10 Gigabit Ethernet
Ports
Performance
Max Units In A Stack
8
Routing Protocol
Authentication Method
RADIUS, TACACS+
2 x 10GBase-T RJ-45 , 2 x 10GBase-X SFP+ , 1 x management (Gigabit LAN) RJ-45 , 1 x serial (RS-232) RJ-45 , 1 x console (mini-USB) , 1 x USB Type A , 48 x 1000Base-T RJ-45
Internal power supply
Installed Qty
1
Max Supported Qty
2
Power Provided
150 Watt
AC 120/230 V
Europe, Americas
Limited warranty - lifetime
C4YZ C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
C4YZ NETGEAR 150W 100-240VAC Power Supply Unit In Stock £183.51
C4YZ C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £14.87
C4YZ C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.71
Ports: 52
Managed: Yes
POE: No
Brand: NETGEAR
Price Range Ex VAT: £1500+
