NETGEAR M4300 48-port 10G SFP+ Managed Switch
Quicklinx: FG2TWS00 Mfr#: XSM4348FS-100NES
Type: 10 Gigabit Ethernet
Ports: 48
Data Transfer Rate: [N/A]
Managed: Yes
POE: No
£4,259.99 ex VAT
£5,111.98 inc VAT
Stackable Managed Switch with 48X SFP+ 10Gb Ports - IT Core & AV-over-IP
  • Robust security
    Equipped with advanced encryption algorithms including 2048-bit RSA, 256-bit SHA-2, and 512-bit SHA-2, alongside RADIUS, Secure Shell v.2 (SSH2), and TACACS+ authentication methods, this switch ensures secure network access and data transmission.
  • High performance
    With a switching fabric bandwidth of 960 Gbps and a throughput of 714 Mpps, the NETGEAR M4300-48XF delivers high-speed data processing and transmission, catering to demanding business applications.
  • Extensive connectivity
    Featuring 48 10GBase-X SFP+ ports and 2 shared 10GBase-T ports, this switch offers versatile connectivity options for a wide range of network configurations and high-speed data requirements.
  • Advanced networking features
    Supports a comprehensive suite of Layer 3 switching capabilities, including ECMP, IGMP, MLD, OSPFv2/v3, PIM-DM/SM/SSM, RIP-2, and static IP routing, enabling efficient network traffic management and routing.
  • Energy efficient
    Certified with ENERGY STAR for energy efficiency, featuring front-to-rear airflow design and hot-plug power supplies, this switch optimizes power usage and cooling, reducing operational costs.
NETGEAR M4300-48XF - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
48 x 10GBase-X + 2 x shared 10GBase-T
Performance
Switching fabric bandwidth: 960 Gbps , Throughput: 714 Mpps
MAC Address Table Size
128K entries
Jumbo Frame Support
9KB
Routing Protocol
RIP-2, IGMP, VRRP, OSPFv2, PIM-SM, static IP routing, PIM-DM, OSPFv3, PIM-SSM, ECMP, policy-based routing (PBR), MLD, MSTP, RSTP
Remote Management Protocol
SNMP, RMON, Telnet, SNMP 3, HTTP, HTTPS, SSH-2, CLI, SCP, SFTP, DHCP, IPv4, IPv6, RSTP, TACACS+, RADIUS
BOOTP support, ARP support, auto-uplink (auto MDI/MDI-X), DoS attack prevention, DiffServ support, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, SNTP support, NSF, sFlow, PVST+, UDLD, LLDP support, DHCP relay, LACP, RSPAN, PVRST, MIB, dual firmware images, CoS, PTP, STRG, AAA, UDP, PIM, 56MB packet buffer
IEEE 802.1p, IEEE 802.3af, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az, IEEE 802.1AX
AC 120/230 V
Power Redundancy
Optional
44 cm x 34.5 cm x 4.4 cm
5.86 kg
United States, Europe
NETGEAR lifetime warranty
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
Performance
128K entries
Jumbo Frame Support
9KB
Routing Protocol
Encryption Algorithm
SHA, MD5, SSL 3.0, 2048-bit RSA, 256-bit SHA-2, 512-bit SHA-2, TLS 2.0
Authentication Method
RADIUS, TACACS+, Secure Shell v.2 (SSH2)
: 800 MHz
RAM
1 GB
Flash Memory
256 MB
48 x 10GBase-X SFP+ , 2 x 10GBase-T RJ-45 , 1 x management (Gigabit LAN) RJ-45 , 1 x serial (RS-232) RJ-45 , 1 x console (mini-USB) , 1 x USB Type A
Installed Qty
1
Max Supported Qty
2
Power Redundancy
Optional
Power Provided
250 Watt
AC 120/230 V
152.4 Watt
80 PLUS Certification
80 PLUS
Front-to-rear airflow
MTBF
657,392 hours
SCCP
44 cm
34.5 cm
4.4 cm
5.86 kg
Limited warranty - lifetime
Ports: 48
Managed: Yes
POE: No
Brand: NETGEAR
Price Range Ex VAT: £1500+
