NETGEAR M4300-28G Managed Switch
STACKABLE SWITCH FOR INTELLIGENT EDGE
Quicklinx: C4YLWS00 Mfr#: GSM4328S-100NES
The NETGEAR M4300 Switch Series delivers L2/L3/L4 and IPv4/IPv6 rich services for enterprise edge and SMB aggregation deployments with unrivaled ease of use: 10 Gigabit models can seamlessly stack with 1 Gigabit models within the series. Non-stop forwarding virtual chassis architecture provides advanced High Availability (HA) with hitless failover, that is, distributed link aggregation allows for load balancing and virtually zero downtime. License-free L3 feature set includes static routing, policy-based routing, RIP, VRRP, OSpiv as well as Multicast PIM routing. The NETGEAR M4300 Switch Series is ready for the future, with Software-defined Network (SDN) and OpenFlow 1.3 enabled for your network.
M4300-28G comes with 24 ports 1G, 2 ports 10GBASE-T and 2 ports 10GBASE-X SFP+ in a full-width form factor. All 4 ports 10G are independent and can be used for stacking or uplinks: they are 1G backward compatible. M4300-28G is delivering resilient and secure access layer in campus LAN environments and commercial buildings. Ideal for server and storage applications: 1+1 PSU protection and front to back cooling ensure hot and cold aisle compliance.
  • Robust Performance
    With a switching capacity of 128 Gbps, the NETGEAR M4300-28G ensures efficient handling of network traffic, maintaining optimal performance even under heavy loads.
  • Comprehensive Connectivity
    This switch offers a wide range of connectivity options including 24 1000Base-T ports for high-speed Ethernet connections, 2 10GBase-T and 2 10GBase-X ports for uplinking or stacking, and additional ports for management, serial, and USB connections, catering to a variety of network setups.
  • Advanced Layer 3 Features
    Equipped with Layer 3 switching capabilities, the NETGEAR M4300-28G supports complex routing protocols such as OSPF, RIP, and VRRP, enhancing network efficiency and resilience.
  • Enhanced Security and Management
    Features like Access Control List (ACL) support, dynamic ARP protection, and advanced authentication methods including RADIUS and TACACS+ ensure secure network access and management.
  • Efficient Network Organization
    Stackable up to 8 units and manageable via CLI, HTTPS, SNMP, SSH, and Telnet, this switch allows for simplified network management and scalability.
NETGEAR M4300-28G - switch - 28 ports - Managed - rack-mountable
Switch - 28 ports - L3 - Managed - stackable
Enclosure Type
Front to back airflow rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
2 x 10/100/1000/10000 + 2 x 10 Gigabit SFP+ + 24 x 10/100/1000
Performance
Switching capacity: 128 Gbps
Routing Protocol
OSPF, RIP, IGMPv2, IGMP, VRRP, PIM-SM, PIM-DM, IGMPv3, MLDv2
Remote Management Protocol
SNMP, Telnet, HTTPS, SSH, CLI
ARP support, DiffServ support, IPv6 support, STP support, RSTP support, VRRP support, DHCP snooping, ACL support, QoS, MLD snooping, STP Root Guard, IPv4 support, LACP support, DHCP relay, RSPAN, PVRST, dynamic ARP protection, IP source guard, BPDU, LISP ASM, SSM
IEEE 802.3ad (LACP), IEEE 802.3az
AC 120/230 V
Europe, Americas
NETGEAR lifetime warranty
Enclosure Type
Subtype
10 Gigabit Ethernet
Ports
Performance
Max Units In A Stack
8
Routing Protocol
Authentication Method
RADIUS, TACACS+
2 x 10GBase-T RJ-45 , 2 x 10GBase-X SFP+ , 1 x management (Gigabit LAN) RJ-45 , 1 x serial (RS-232) RJ-45 , 1 x console (mini-USB) , 1 x USB Type A , 24 x 1000Base-T RJ-45
Internal power supply
Installed Qty
1
Max Supported Qty
2
AC 120/230 V
Europe, Americas
Limited warranty - lifetime
C4YL C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.67
C4YL C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.82
