Robust security
Equipped with advanced encryption algorithms including 2048-bit RSA, 256-bit SHA-2, and 512-bit SHA-2, alongside RADIUS, Secure Shell v.2 (SSH2), and TACACS+ authentication methods, this switch ensures secure network access and data transmission. -
High performance
With a switching fabric bandwidth of 480 Gbps and a throughput of 357 Mpps, the NETGEAR M4300-24XF delivers exceptional performance for high-demand network environments. -
Comprehensive network features
Supports a wide range of networking features such as ARP support, BOOTP support, DHCP relay, DiffServ support, and more, providing flexibility and control over network traffic management. -
Advanced Layer 3 switching
Layer 3 advanced switching capabilities including policy-based routing (PBR), static IP routing, and support for routing protocols like OSPFv2, OSPFv3, and RIP-2, enabling efficient network routing and segmentation. -
Efficient power management
The internal power supply is 80 PLUS certified, ensuring efficient power usage with a maximum power consumption of 87.2 W, contributing to lower operational costs.
- NETGEAR M4300-24XF - switch - 24 ports - Managed - rack-mountable
- Switch - 24 ports - L3 - Managed - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- 10 Gigabit Ethernet
- Ports
- 24 x 10GBase-X + 2 x shared 10GBase-T
- Performance
- Switching fabric bandwidth: 480 Gbps , Throughput: 357 Mpps
- Capacity
- Packet buffer size: 32 MB
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- 9KB
- Routing Protocol
- RIP-2, IGMP, VRRP, OSPFv2, PIM-SM, static IP routing, PIM-DM, OSPFv3, PIM-SSM, ECMP, policy-based routing (PBR), MLD, MSTP, RSTP
- Remote Management Protocol
- SNMP, RMON, Telnet, SNMP 3, HTTP, HTTPS, SSH-2, CLI, SCP, SFTP, DHCP, IPv4, IPv6, RSTP, TACACS+, RADIUS
- BOOTP support, ARP support, auto-uplink (auto MDI/MDI-X), DoS attack prevention, DiffServ support, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, SNTP support, NSF, sFlow, PVST+, UDLD, LLDP support, DHCP relay, LACP, RSPAN, PVRST, MIB, dual firmware images, CoS, PTP, STRG, AAA, UDP, PIM
- IEEE 802.1p, IEEE 802.3af, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az, IEEE 802.1AX
- Power
- AC 120/230 V
- 21.2 cm x 34.5 cm x 4.4 cm
- 3.56 kg
- Localisation
- United States, Europe
- NETGEAR lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Ports
- Performance
- Capacity
- 16K entries
- 9KB
- Routing Protocol
- Encryption Algorithm
- SHA, MD5, SSL 3.0, 2048-bit RSA, 256-bit SHA-2, 512-bit SHA-2, TLS 2.0
- Authentication Method
- RADIUS, TACACS+, Secure Shell v.2 (SSH2)
- Processor
- : 800 MHz
- RAM
- 1 GB
- Flash Memory
- 256 MB
- 24 x 10GBase-X SFP+ , 2 x 10GBase-T RJ-45 , 1 x management (Gigabit LAN) RJ-45 , 1 x serial (RS-232) RJ-45 , 1 x console (mini-USB) , 1 x USB Type A
- Power Device
- Internal power supply
- Installed Qty
- 1
- Max Supported Qty
- 1
- Power Provided
- 250 watt
- Voltage Required
- AC 120/230 V
- 87.2 watt
- 80 PLUS Certification
- 80 PLUS
- Front-to-rear airflow
- MTBF
- 968,447 hours
- SCCP
- Localisation
- 21.2 cm
- 34.5 cm
- 4.4 cm
- 3.56 kg
- Limited warranty - lifetime
