The NETGEAR M4300-16X (XSM4316PB) ProSAFE Intelligent Edge 16-Port Fully Managed Stackable 10-Gigabit PoE+ Switch delivers L2/L3/L4 and IPv4/IPv6 cost-effective services for mid-enterprise edge with full PoE+ and SMB core deployments with unrivalled ease of use. The M4300-16X can seamlessly stack with 1 Gigabit models within the series (sold separately), enabling spine and leaf line-rate stacking topologies. Non-stop forwarding (NSF) virtual chassis architectures provide advanced High Availability (HA) with hitless failover across the stack. Layer 3 feature set includes static, dynamic and policy-based routing as standard. The NETGEAR M4300-16X is perfect for wireless access, unified communications and professional AV-over-IP installations.
Robust security
With advanced encryption algorithms including 2048-bit RSA, 256-bit SHA-2, and 512-bit SHA-2, alongside RADIUS, Secure Shell v.2 (SSH2), and TACACS+ authentication methods, this switch ensures secure network access and data transmission. -
High performance
Equipped with a switching fabric bandwidth of 480 Gbps and a throughput of 238 Mpps, the NETGEAR M4300-16X delivers exceptional performance for high-speed data processing and transmission. -
Versatile connectivity
Featuring 16 ports supporting speeds up to 10GBase-T with PoE+ capability, this switch offers flexible connection options for a variety of devices while powering them over the Ethernet. -
Comprehensive network features
Supports a wide range of Layer 3 switching features including advanced routing protocols like OSPFv2/v3, PIM, and VRRP, ensuring efficient network traffic management and resilience. -
Efficient management and operation
Manageable via CLI, HTTP, HTTPS, and SNMP among others, with support for sFlow, dual firmware images, and front-to-rear airflow design for optimal performance and ease of management.
- NETGEAR M4300-16X - switch - 16 ports - Managed - rack-mountable
- Switch - 16 ports - L3 - Managed - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- 10 Gigabit Ethernet
- Ports
- 16 x 100/1000/2.5G/5G/10GBase-T (PoE+)
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 500 W
- Performance
- Switching fabric bandwidth: 480 Gbps , Throughput: 238 Mpps
- Capacity
- Packet buffer size: 16 MB
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- 9KB
- Routing Protocol
- RIP-2, IGMP, VRRP, OSPFv2, PIM-SM, static IP routing, PIM-DM, OSPFv3, PIM-SSM, ECMP, policy-based routing (PBR), MLD, MSTP, RSTP
- Remote Management Protocol
- SNMP, RMON, Telnet, SNMP 3, HTTP, HTTPS, SSH-2, CLI, SCP, SFTP, DHCP, IPv4, IPv6, RSTP, TACACS+, RADIUS
- BOOTP support, ARP support, auto-uplink (auto MDI/MDI-X), DoS attack prevention, DiffServ support, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, SNTP support, NSF, sFlow, PVST+, UDLD, LLDP support, DHCP relay, LACP, RSPAN, PVRST, MIB, dual firmware images, CoS, PTP, STRG, AAA, UDP, PIM
- IEEE 802.1p, IEEE 802.3af, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az, IEEE 802.1AX
- Power
- AC 120/230 V
- 21.2 cm x 34.5 cm x 4.4 cm
- 3.22 kg
- Localisation
- United States, Europe
- NETGEAR lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Ports
- PoE+
- PoE Budget
- 500 W
- Performance
- Capacity
- 16K entries
- 9KB
- Routing Protocol
- Encryption Algorithm
- SHA, MD5, SSL 3.0, 2048-bit RSA, 256-bit SHA-2, 512-bit SHA-2, TLS 2.0
- Authentication Method
- RADIUS, TACACS+, Secure Shell v.2 (SSH2)
- Processor
- : 800 MHz
- RAM
- 1 GB
- Flash Memory
- 256 MB
- Status Indicators
- Status
- 16 x 100/1000/2.5G/5G/10GBase-T RJ-45 PoE+ , 1 x management (Gigabit LAN) RJ-45 , 1 x serial (RS-232) RJ-45 , 1 x console (mini-USB) , 1 x USB Type A
- Power Device
- Internal power supply
- Installed Qty
- 1
- Max Supported Qty
- 1
- Power Provided
- 600 Watt
- Voltage Required
- AC 120/230 V
- 610 Watt
- 80 PLUS Certification
- 80 PLUS
- Front-to-rear airflow
- MTBF
- 690,301 hours
- SCCP
- Localisation
- 21.2 cm
- 34.5 cm
- 4.4 cm
- 3.22 kg
- Limited warranty - lifetime
