The NETGEAR M4300 Switch Series delivers L2/L3/L4 and IPv4/IPv6 rich services for enterprise edge and SMB aggregation deployments with unrivaled ease of use: 10 Gigabit models can seamlessly stack with 1 Gigabit models within the series. Non-stop forwarding virtual chassis architectures provide advanced High Availability (HA) with hitless failover, that is, distributed link aggregation allows for load balancing and virtually zero downtime. License-free L3 feature set includes static routing, policy-based routing, RIP, VRRP, OSpiv as well as Multicast PIM routing. The NETGEAR M4300 Switch Series is ready for the future, with Software-defined Network (SDN) and OpenFlow 1.3 enabled for your network.
M4300-12X12F comes with 12 ports 10GBASE-T and 12 ports 10GBASE-X SFP+ in a half-width form factor. All 24 ports are independent and 1G backward compatible for progressive transition to 10G speeds. Ideal for server and storage aggregation: two half-width M4300 switches can be installed in a single rack space. M4300-12X12F is line-rate with 480Gbps fabric for SMB core applications as well as spine and leaf stacking architectures.
Robust security
Equipped with RADIUS and TACACS+ authentication methods, the NETGEAR M4300-12X12F ensures secure network access control, offering peace of mind for network administrators. -
High performance
With a switching capacity of 480 Gbps, this switch is designed to handle the demands of large data transfers and high-speed connectivity, ensuring efficient network performance. -
Advanced networking
Supporting a wide range of Layer 3 switching features such as ARP support, Access Control List (ACL) support, and Quality of Service (QoS), the M4300-12X12F is capable of sophisticated network management and prioritization. -
Versatile connectivity
Featuring 24 ports, including 12 10GBase-T and 12 10GBase-X SFP+ ports, this switch offers flexible connection options for a variety of network devices and cable types. -
Efficient management
Manageable via CLI, HTTPS, SNMP, SSH, and Telnet, the M4300-12X12F allows for easy and versatile management, catering to a wide range of administrative preferences.
- NETGEAR M4300-12X12F - switch - 24 ports - Managed - rack-mountable
- Switch - 24 ports - L3 - Managed - stackable
- Enclosure Type
- Front to back airflow rack-mountable 1U
- Subtype
- 10 Gigabit Ethernet
- Ports
- 12 x 10/100/1000/10000 + 12 x 10 Gigabit SFP+
- Performance
- Switching capacity: 480 Gbps
- Routing Protocol
- OSPF, RIP, IGMPv2, IGMP, VRRP, PIM-SM, PIM-DM, IGMPv3, MLDv2
- Remote Management Protocol
- SNMP, Telnet, HTTPS, SSH, CLI
- ARP support, DiffServ support, IPv6 support, STP support, RSTP support, VRRP support, DHCP snooping, ACL support, QoS, MLD snooping, STP Root Guard, IPv4 support, LACP support, DHCP relay, RSPAN, PVRST, dynamic ARP protection, IP source guard, BPDU, LISP ASM, SSM
- IEEE 802.3ad (LACP), IEEE 802.3az
- Power
- AC 120/230 V
- Localisation
- Europe, Americas
- NETGEAR lifetime warranty
- Enclosure Type
- Subtype
- Ports
- Performance
- Max Units In A Stack
- 8
- Routing Protocol
- Authentication Method
- RADIUS, TACACS+
- 12 x 10GBase-T RJ-45 , 12 x 10GBase-X SFP+ , 1 x management (Gigabit LAN) RJ-45 , 1 x serial (RS-232) RJ-45 , 1 x console (mini-USB) , 1 x USB Type A
- Power Device
- Internal power supply
- Voltage Required
- AC 120/230 V
- Localisation
- Europe, Americas
- Limited warranty - lifetime
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.76 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £13.84 |
